GPU Review: Low Profile & Single Slot RTX A2000 8GB / 3050Ti 8GB from TaoBao
awc
27
short update: I made a custom cooler for the card, because the original one did not work well for my 2.7L MoDT build (the fan was sitting right above the PSU)
for my new cooler I used a 55mm 5V DELTA blower (NS55B06) and 12V to 5V step down module - the fan can be controlled via "FanControl" software
for the heatsink I used a 3mm copper plate, 138C solder paste and some copper fins from TaoBao - you can find them for example here (link)
I have attached the drawing of the copper plate to this post - if someone needs it
now this should work better:
some testing results:
PS: the manufacturer told me they are also working on a new cooler for their cards - this time with blower fan at the rear end, so that it can actually be used in small PCs like the Minisforum MS01 and Lenovo Tiny
I was thinking about buying one of these cards and asked about the new cooler. Apparently they can ship it with my order. I will update if I end up buying one, but I got a video of the cooler and it looks amazing. I think the fan will be adjustable too on it.
I was also told they are working on a desktop single slot low profile rtx 4060. Although apparently it has worse compatibility tho. They said they got 7600-8100 in timespy with it, which would be insane
REVOCCASES
REVOCCASES
2,237
3,651
www.revoccases.com
yeah, their single slot low profile RTX 4060 (mobile) is currently in beta testing... it will likely use a cooler design based on my A2000m mod (I posted here before) and will have a TDP of 85 to 95W. At 70W (slot powered) the performance was kinda disapointing, so they decided to increase the wattage and use an additional power connector... guess we still need to figure out how to use this card in the MS-01 :p
some teaser pics:
I'll start a new thread after I got my hand on a sample ;)
go.d-bq
24
some teaser pics:
WoW! Where I can buy this videocard???)))
1,254
some teaser pics:
Given I can run my 140W RTX A2000 from a PCIe slot, I reckon there's a few motherboards that would happily run at 85-90W from a slot... not that I'd necessarily recommend it.
Reactions: REVOCCASES
jasonho
this is certainly very encouraging :)
With this config, most 3A titles should sail smoothly on 2k resolution using dlss :)
some teaser pics:
Gingerbeer
142
128
some teaser pics:
Sata powered? Do we know the board dimensions? This might tip me over the edge and make me buy a MS-01.
1,254
I think it has a custom single-row 8-pin connector pigtail to PCIe power. I’d wait for availability of the actual GPU before committing but that’s just me ;)
REVOCCASES
REVOCCASES
2,237
3,651
www.revoccases.com
short update concerning the drivers for the A2000 8G (also added to first post)
Using the latest, official NVIDIA drivers via *inf method:
1) go to nvidia.com and dowload the latest Laptop GPU drivers
2) extract the driver files, e.g. via 7zip
3) go to Windows Device Manager and navigate to the "unknown device / graphics adapter"
4) select update driver and click browse for drivers
5) click choose available drivers on my computer, then click Install from disk
6) navigate to folder where you downloaded the driver and unziped it, find the [Display.Driver] folder, select the first INF file
7) a list with several GPU models should pop up, scroll down to the A2000 Laptop models and choose the 3rd one from top, then click OK
8) now the driver should install
9) after reboot, go to Windows Store and install "Nvidia Control Panel"
10) done
Mattnz24
Thanks for all the great info here. I've spent the last few days and think I'll pull the trigger on the a2000, 4060 is a bit too expensive, my psu is 280w and only have PCIe x 16 3.0
Anyway just wanted to possibly state the obvious. TAO BAO is great but I don't speak Chinese, however I found with taking screenshots on my phone and using Google translate I could read everything. Never used it before and was amazed at how well it works!
Gingerbeer
142
128
Even on PCIE 3.0 it'll smash the A2000 - my 4 litre rig was PCIE 3.0 and I went from A2000 to 4060LP. I run the 4060 and a 5600G on a 250W PSU, without issue, and that's before I undervolted the 4060.
Chrome has an English translation option on Taobao and it seem to work ok - I haven't bought anything from there or used it extensively, but it seemed to work ok.
Mattnz24
Even on PCIE 3.0 it'll smash the A2000 - my 4 litre rig was PICE 3.0 and I went from A2000 to 4060LP. I run the 4060 and a 5600G on a 250W PSU, without issue, and that's before I undervolted the 4060.
Nice! What stats did you get on that?
REVOCCASES
REVOCCASES
2,237
3,651
www.revoccases.com
seankirt2
so i bought an rtx 3050m locally he came from mainland and the card looks exactly the same in the post but it wont display when plugged in the gpu tried it on my main pc didn't post and tried it on an m920q. and when plugged inside the m920q it doesn't show on the display adapters is it a cpu incompatibility that it doesn't detect or the card itself. my main rig has a ryzen 5 5600x and the m920q has a i5 5800t. tried using a 1050ti and it showed up on the m920q. any ideas?
ponymei
10) done
I have bought this exact same gpu from the same seller (it seems they have updated the cooler to blower style, even on the cheaper aluminum model).
I installed the drivers successfully using this method, but in some games DLSS option is not showing up at all. COD Warzone and Black Myth Wukong are 2 games I have tested where DLSS is not an option. However, if I switch to the FrankenDriver DLSS options are working properly. Are there any other alternative methods of installing the drivers with DLSS working reliably? I am going to use FrankenDriver for now, but in the event the author of these drivers stops releasing new drivers, I wanted to know if there is any other alternative.
REVOCCASES
REVOCCASES
2,237
3,651
www.revoccases.com
you could try to use one of the modded drivers for the MOREFINE G1 eGPU
G1 – Google Drive
80m90m驱动,LCD – Google Drive
Nem744
Hi,
Did you try the modded MOREFINE G1 eGPU drivers mentioned by REVOCCASES in the post above for solving your DLSS issue? Did they work?
ponymei
Hi,
Hi,
I did not try those drivers, but I can tell you what worked for me. I downloaded the latest nvidia drivers for A2000 8GB Laptop GPU. I then used NVCleanInstall to install those drivers. Under "Installation Tweaks", I checked the "Add Hardware Support" option and selected the first "RTX A2000 8GB Laptop GPU" that appears in the "Template" options. I also selected the "Use method compatible with Easy-Anti-Cheat" option.
That fixed all the issues I was having with the GPU.
