Figured this picture would make following the changes easier, also thanks to Revenant for posting about it on the home page!
Measurements: 349.525 x 35 x 139.81mm
Support Improvement:
Alluminum: 45mm [27mm rad + 15mm & 1x 30mm on 120mm bracket]
V2 3d-Print: 60mm [27mm rad + 2x 30mm on 240mm bracket]
Files can be found here: [makerworld]
*One issue still exists, teeth need a slight inner bevel on the lip between the grills and the tooth, which was present on the white matte PLA as it deformed slightly, but the black matte printed them perfectly square.
Link to Revenant's article: [smallformfactor]
