LukeD
Case Designer
Jun 29, 2016
525
1,337
Yep, soldered 2 together. A bit of a messy process but it can be done.
I've approached two places to get custom SLI cables made but they both shied away.
I need to keep looking or wait for Lian Li to offer them for sale, since they are coming out with a case with a very similar layout to mine.
HeroXLazer
707
476
What places?
LukeD
Case Designer
Jun 29, 2016
525
1,337
You need 2 SLI cables.
Cut off the connector on each end of each cable.
Desolder the pins left over from the SLI plastic connector (probably the most time consuming part) (do this for each cable)
Heat up the end of the SLI cable so you can separate the ribbon from the clear PCB. (do this for each cable)
Line up the cables and solder through.
I think I have some pictures. If not, I'll be making some in the next few days. I'll take pics of the process.
LukeD
Case Designer
Jun 29, 2016
525
1,337
In the meantime, I'm working on custom length cables for the FSP power supply :)
Reactions: Clarvel
LukeD
Case Designer
Jun 29, 2016
525
1,337
Hahaha that's right Aibohphobia ;) I'd do a lot more to save even 100 ml :) hahahaha
and yes it is a crazy obsession ;)
FCase
FCase
Dec 20, 2015
142
92
I figured you had this line of thought going already; I just could not find where you had mentioned it. Otherwise buyers would be left on their own to find SLI cables that would work. Hopefully you can find a place to get custom cables. Have you asked ModDIY? They may be able to help.
Reactions: LukeD
LukeD
Case Designer
Jun 29, 2016
525
1,337
I haven't asked those guys. I will though. Thanks for the heads up.
I've asked a few companies that produce flexible cables. I can't remember the name exactly but these cables have a specific name.
ModDIY will be on my list to ask ;)
Especially that I have ordered a ton of stuff from them to pull off the 1st project ;)
Reactions: Ceros_X
LukeD
Case Designer
Jun 29, 2016
525
1,337
I was just testing the power supply if i cabled it correctly.... and I couldn't help but run a few tests :)
Forgive me about the picture quality ... the photos were taken with a potato :)
P.S. And when i say "With Case" it also obviously means with my makeshift SLI cables and PCI risers :)
Reactions: ricochet
HeroXLazer
707
476
I feel like Vega would be the perfect candidate for this case because of the integrated XFire.
LukeD
Case Designer
Jun 29, 2016
525
1,337
It would. Would love to test it in there if AMD helps me out :)
However, the SLI cables are now nicely hidden :) more pictures of that coming soon.
Reactions: Ceros_X
HeroXLazer
707
476
Still, they are custom. But, if you do sell this, include a custom SLI cable. Some people don't want to go through the pain.
Reactions: LukeD
