6,591
@Linero I removed a lot of stuff that need not be said. I'll ask you both to leave it at this point - your comments demanding information from LukeD was too far in an of itself, as was the original comment by @xninetynine . I denatured his comment somewhat, but this reply ends it.
Needless to say, LukeD doesn't owe anyone any information - as this project hasn't hit sales or production yet.
IDontknowMuch
There has to be someone capable of creating a HB riser cable. Is this the only thing stopping the project? Why not ask Josh Sniffen the creator of the Skyreach S4 Mini case or someone else to help make the HB riser cable that you need? I as well as many others are waiting patiently for the release of Orthrus pc case.
MelonGx
Oh I miswrote the word.
What I wanted to say was a HB SLI bridge’s riser cable but not a PCIe one.
Now only RTX3090 supports SLI.
TheClash
32
Hey @LukeD - any progress updates? Do you think with only the 3090 supporting SLI you might have missed the boat...to be honest I would still use you case without a dual card!
Reactions: Windfall
LukeD
Case Designer
Jun 29, 2016
481
1,254
I don't have any solid updates to be honest.
While I do think that the "use case" of dual GPU's still exists in the 2000 series Nvidia cards and earlier as well as the new AMD cards, it definitely shrinks the possible user base.
Canities
25
@LukeD
I would still be interested in the case. An additional expansion card and water cooling in a small m-atx form factor is a definite thumbs up! I was thinking, there might be a possibility for a custom riser to allow multiple single slot cards in the bottom holder (for m-atx motherboards)?
Canities
Reactions: LukeD
phantommaggot
I'd argue that this would be great for a modern stream system with a gpu and capture card. Sort of like how Linus built that ITX system with bifurcation and a GPU/Capture card.
Or, For me, Using multiple OS on one system for security reasons. (since consumer cards still don't have SRIOV or something like it)
Lets not forget, that you could technically run the new RX cards in Crossfire... and they do pretty well.
Tahsin_28
So can someone give me a tldr? This was by fav case wayy before linus reviewed it n would have shelled out any money if sli was still a thing "for gaming".
LukeD
Case Designer
Jun 29, 2016
481
1,254
Yeah this is the challenge right now guys. Since the project has gone on hiatus, a lot of things have changed.
Is there enough interest still in the case considering SLI is no longer possible ?
Even the 2000 series cards would not theoretically be supported in this case as designing a new long enough flexible SLI bridge would not be possible / feasible.
So the question is, is there enough interest in this group to see this case go into production to support DUAL GPU's that don't need an SLI bridge or perhaps people that want one GPU slot and one slot for something else, like a capture card or sound card.
I think we need to take some sort of poll, so see if the interest still exists in the case.
Ricky
92
36
I’d be interested, although MATX as a motherboard form factor seems excessively rare nowadays, at least on the higher end. Really sad considering I’d be perfectly happy with two slots.
VegetableStu
1,946
2,607
w360 mentioned there might be cards going 3.5 slots on the next generation. at its current state, only watercooling would be feasible, thus further increasing its niche
if the orthrus goes 4 slot wide, there's probably not enough PCIe lanes to justify the lower deck (maybe a custom disk backplane could fill the space that wide), and it'll be twice as thick
speaking of which, if one wants a small board with PCIe lanes, they'd have to turn to server boards, and those are probably adopted too few outside the enterprise space to be considered above speciality. it's the chaotic end of sparing no expense for the most compact and performant system
to re-iterate, nvidia and AMD is moving away from multi-GPU for consumers. it's increasingly likely that those who want two xx90-class cards would fancy a larger case, or would be alone in trying to cram that into a shoebox (edit: and that's before considering the power draw. 1kw power supplies just barely started becoming a thing in SFX-L)
it breaks a few hearts to say this, but there might not be much volume for engineering something new for the past when it comes to PC hardware
