That is what I am waiting for.Hopefully soon, a medium stack just for 2x 120mm fans would be very nice to have.
Make it happen? Please? Lol
Me too. I think a single 240mm rad is just fine instead of 2 for me. I just would love to see a medium stack so I can have 2 intake fans from bottom. If someone can 3d print the mod and sell, I would love to see that.That is what I am waiting for.
In the stack unit? I know but I rather have a rather fit size for the fans instead of having a stack with am empty gap. It just looks weird.Two 120 fans can go in the top or bottom instead of the radiator. I asked on Twitter.
you should tbh, tons of improvements that can be made. wait on like a node 202 or a cheap rajintek metis plus or something for now and see how things pan out for sure. cheers.Now I’m wondering if I should hold off for v2 or 3.
~~I'm confused as to why their magnetic because I believe the ghost, just like the steck, are made of aluminum...~~Ok everyone I just discovered Demciflex
Demcifilter.com | Computers & Electronics Dust Filters
demcifilter.com manufacture demciflex and distribute computer and electronics air filters fan filters that fits to the case magnetically and ship globaly.www.demcifilter.com
They do custom dust filters and have some for the ghost and dan.
I imagine using the ghost s1 filters for the side and top would work just fine.
They also come in black and white.
Perfect.
My one problem is that all these SFf cases rarely come with dust filters.
anyone who has this case know if side and top dust filters would work with the vented panels? either custom ones I guess? I have 3 cats and a terribly old carpeted room.
maybe an upgrade for V2 perhaps
has anyone done air cooled builds with the tempered glass? im thinking of two 120s instead of a radiator and a 120 in the bottom running exhaust.
I use a 1070mini from MSI and an 8700 non K
going to upgrade to the gigabyte 2070mini when possible.
before anyone says anything I find AIOs annoying to work with. and I don't overclock nor care much for it. if I do overclock its on the GPU
and Im running a blower card so it stay pretty cool already.
I also run 1080p at 60fps which is fine for me.
also how is traveling with this case? can I throw it in a backpack and take it with me? waaaay lazy to search the forums if any of this has been asked before.
The pannels are aluminum, they do get 2 strips of magnetic adhesive, but that won't help much when adding a magnetic dust filter.I'm definitely no expert, but the panels are already inadequately vented. I wouldn't recommend blocking them even more with dust filters. The panels are magnetic so blowing the dust out regularly would be an easy alternative.
i run this setup with the vented panels, it creates a negative pressure environment and forces air in through the sides and works pretty well. I am not sure how this would work with glass panels, you might be able to raise the glass slightly off but then the air intake would be right next to the fans. You would probably want to create a wind tunnel effect with bottom intake and top exhaust, with plenty of clearance on the bottom for intake. this could work if you're not running hardware with high power draw.
also, i am using the top rad mount for 2x 140 fans with 120mm mounts, but I found airflow improved a bit when i cut out the middle sections, so its worthwhile doing that to increase airflow if you're planning to run this setup
