Production Nouvolo Steck - SFF 8.7-11.2L ITX PC Case, supports liquid cooling
Hifihedgehog
Editor-in-chief of SFFPC.review
May 3, 2016
459
408
www.sffpc.review
The specifications of my test system are the following:
CPU: AMD Ryzen 7 1700 at 3.9 GHz, 1.34375V
CPU Cooler: Noctua NH-L12 with Delta AFC0912D-PWM 92mm Fan
Motherboard: Asus ROG STRIX X470-I GAMING
RAM: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3600 Cl 15 Memory (F4-3600C15D-16GTZ)
GPU: EVGA - GeForce GTX 1080 Ti 11GB SC2
Primary SSD: Samsung - 970 Evo 500GB, M.2-2280
Secondary SSD: Samsung - 850 EVO 500GB 2.5"
PSU: Enermax - REVOLUTION SFX 650W
Poblopuablo
816
465
My test specs are as follows:
CPU: 4690k (4.4 @1.3125)
CPU cooler (option 1): Corsair h60 aio
CPU cooler (option 2): Id cooling is-60
Motherboard: Asrock Z87e itx
Ram:2x8gb 1600mhz g.skil
Gpu:MSI Rx 580 8gb
Ssd: SanDisk 500gb
Psu:Corsair sf450 gold
If all goes well I might transfer my main build into this(currently in a salvo s400):
CPU: ryzen 1600 3.9 all cores.(planning to upgrade to 7nm ryxen next year)
CPU cooler (option 1) cryorig c7 with noctua fan and 2x 40mm fans
CPU cooler (option 2): Corsair h60
Cpu cooler (option 3): Id-cooling is-60
Motherboard: Asrock b350 itx
Ram: 2x8gb lpx 3200mhz b-die
Gpu: FE 1080 (with a EVGA SC acx cooler)
Ssd: don't remember... 500gb SSD
Psu: Corsair sf600 gold
MadDrake
@MadDrake you doing custom loop? Make sure you share your build with us. I am interested to know how one would fit the reservoir.:)
I'm going to try it's gonna be pretty tight. My first try at Hardline water cooling. Here's my specs(grabbed the format from someone)
CPU: AMD Ryzen 5 1600x
CPU Cooler: ek supremacy Evo
Motherboard: biostar racing x370gtn
RAM: 1 8gb stick of Samsung ddr4 2133mhz
GPU: EVGA - GeForce GTX 980ti Classified will have ek classy block on it.
Primary SSD: adata 128gb m2 su800
Secondary HDD: 2tb Western digital blue.
PSU: fsp dagger 600w
This build barely fit in my fractal nano . The rad for it is thicc 48mm. I'll have two noctuas that are thin. Should fit. But might need to do a lot of thinking to get it in.
Reactions: Hifihedgehog
Allhopeforhumanity
548
539
I've got a couple options for the test system myself:
Option 1:
CPU: i7 7700
CPU Cooler: Noctua L9i
Ram: 2x16gb 2666 DDR4
GPU (option 1): ASUS 1050ti
GPU (option 2): Evga GTX 780
PSU: Corsair SF450
SSD: 256gb 850 evo
SSD: 1Tb Crucial ssd
Option 2:
CPU: R5 1500
CPU Cooler: Wraith Cooler
Ram: 2x8gb 3000mhz DDR4
PSU: Corsair SF450
SSD: 256gb 850 evo
HDD: 1 TB 2.5in 7200RPM hdd
Both are currently otherwise sitting in Node 202's and which ever one I decide to transfer, I'll make sure to do some thermal comparisons between the enclosures.
Engr62
127
77
I have two possible builds for this case.
Configuration #1:
CPU: Intel i7-4790K
CPU Cooler: Raijintek Pallas
Motherboard: Asus H81I-Plus
RAM: G.Skill Ripjaws X (2x8 Gb)
GPU: EVGA GTX 1060 SC 6 Gb (single fan)
Primary Samsung 850 Evo 250 Gb 2.5"
Secondary: 1 Tb 2.5" HDD (extra space when using short GPU)
PSU: Corsair SF450
Configuration #2:
CPU: AMD Ryzen 7 1800X
CPU Cooler: Noctua NH-L12 with only the bottom 92mm fan
Motherboard: ASRock AB350 Gaming ITX/ac
RAM: G.Skill Ripjaws V (2x8 Gb)
GPU: MSI GTX 1070 Gaming X
Primary SSD: Toshiba M.2 NVME 500Gb
Secondary SSD: Adata SU650 960 Gb 2.5"
PSU: Corsair SF450
The Ryzen 7 1800X system is currently in my NCASE M1 with a Noctua NH-D9L (2 fans) cooler (I love that cooler) and a dual fan EVGA GTX 1060 6 Gb. The MSI GTX 1070 Gaming X is too tall to fit in the M1, so that is why I may move the 1800X to the Nouvolo Steck.
Reactions: fabio and Chinaman
Longbow072
92
50
Oh, rats I didnt realize that, thanks for the heads up. So this is a 7th gen chip and will need a 7th gen board? Or a 9th gen? No matter if anything it makes it cheaper for me.
Although PC Parts Picker didnt show any conflicts...
whatanoob
38
40
You need a motherboard with an Intel 100 series or 200 series chipset, but PCPartPicker should definitely help you with that.
Maybe you didn't input the right parts, because when I do it definitely shows they're incompatible.
vex_sb
60
What is the price of this case ???
- the mesh on top looks pretty restrictive ??
- is it possible to put 2 extenders 1 on top of the other ??
Longbow072
92
50
Told you guys I was a noob. But should be a good perspective for how easy the case is to work in and build in even for a novice.
Longbow072
92
50
planned asus strix mobo is scarce or not made anymore. But msi still makes the z270i pro carbon so thats looking like the likely option. Thanks for the heads up. Trying to do this upgrade as cheaply as possible from what I have available.
Reactions: chyll2
Hifihedgehog
May 3, 2016
459
408
www.sffpc.review
I just finished running the classic cardboard box test bench setup and unlike that ASRock, everything is passing and as good as gold on this Asus. So far, so good! This Asus X470 board is so much better than the ASRock AB350 one I had. For one thing, the CPU fan controller actually follows the real CPU temperature and not the board processor temperature and it is practically instantaneous in adjusting to temperature transients. The ASRock was always pokey about ramping up the fan and its temperature reference followed some oddball CPU sensor on the board rather than the processor’s own temperature sensor. The onboard sound is also delicious. I can immediately tell the improvement with my audiophile grade headphones. Of course, the fan and audio is just the tip of the iceberg and there are so many other things to rave about. Luckily, they had this board on clearance for only $157 at my local Micro Center!
Poblopuablo
816
465
Configuration #1:
CPU: Intel i7-4790K
PSU: Corsair SF450
Configuration #2:
PSU: Corsair SF450
The Ryzen 7 1800X system is currently in my NCASE M1 with a Noctua NH-D9L (2 fans) cooler (I love that cooler) and a dual fan EVGA GTX 1060 6 Gb. The MSI GTX 1070 Gaming X is two tall to fit in the M1, so that is why I may move the 1800X to the Nouvolo Steck.
The Pallas is an awesome cooler, but it has fitment issues with many motherboards. Did you by chance try to get it on your asrock b350? Wondering bevabec i have the same board, but didn't buy it again(had it on another system) because of fitment issues
macbosco
304
710
www.nouvolo.com
Thanks a lot!! That's FAST!
I would really appreciate if you guys could post your builds. They will be used to support my request for further reviews by other youtubers and/or the rest of the community. All these have been delivered to you by Fedex, which should reach you in matter of days. I can only tell you that it is NOT cheap to ship this way, and I don't make any money out of this batch of sales. But I feel that same excitement as you do, and I wouldn't want to wait too long.
fabio
1,885
4,325
You will be not disappointed!
I guess next weekend I can have it completed! (At the latest week after, It’s only a matter of deadline at work).
Thank you for so much support!
Reactions: Engr62 and Chinaman
Hifihedgehog
May 3, 2016
459
408
www.sffpc.review
Here is my “über original” cardboard box test bench. (Quick and dirty morning photo before work. No paper white background... yet. ;) )
Reactions: talkion and chyll2
Engr62
127
77
Yeah, the Pallas is a total pain in the rear to work with. Lots of coolers don't have a fixed cross-bar that goes across the cold plate, but the difficulty of installing a cooler with a non-fixed cross-bar goes up exponentially with such a short, wide cooler. Plus, installing the fan clips is unnecessarily hard. The Pallas does a nice job of cooling, but I don't recommend it. It's RAM clearance is terrible, and it's really restrictive on which orientation you can mount it in. For instance, if you have the ends of the heat pipes facing towards the I/O, you can't install the I/O shield because it will interfere.
I had intended to install it on the Ryzen 7 1800X, but my Ripjaws V RAM is too tall. I had Ripjaws X DDR3 on the i7-4790K set up that I had to swap for Crucial Ballistix (cost me $60) in order to get it to fit on that. With the price of DDR4, I just couldn't afford to swap out the Ripjaws V on the Ryzen 1800X system for something shorter. Other than the RAM height, I think it would have fit on the ASRock AB350.
