Production Nouvolo Steck - SFF 8.7-11.2L ITX PC Case, supports liquid cooling
Xaeons
30
Can I fit a ZOTAC GAMING GeForce RTX 2060 SUPER MINI without sacrificing the 2.5 hard drive mount?
It says in the specifications in their website that it's 209.6mm
sami hx
21
Hey guys, i orderd my Steck and i have a Question. I have the Corsair sf600 and i want to cool my i9 9900k with the asetek 645. Is it possible with the cables of the PSU? or is there any other cooler that is capable of cooling the 9900k?
Best Regards
Poblopuablo
816
465
The L12s is pretty good.
Or you can use custom cables from someone like dreambigbyray on Etsy. (They ship from China so they may take a little while to arrive, but they are pretty good) I'd recommend going with the silver plated (your choice of color) cables because they have less bulk then the sleeved cables. Custom lengths can be found on Nouvolo's site in the FAQ.
sami hx
21
Thank you for your fast Reply! The Problem is that products from China really take a Long while until they arrive in Germany :D Thats why i asked if anyone have experience with the stock cables :-)
Xaeons
30
Tis the first time in my whole life assembling computers that I had to bend a power supply cable like this. It took me an hour and a lot of patience ?
Reactions: chyll2
Xaeons
30
That is tempting, I'm from the Philippines and it'll ship quite fast here.
Anyone here using an MSI B450i motherboard and using custom cables? Will 22cm be enough?
I also measured 22cm at most..
2,695
2,825
I had a set of pslate cables made for the Steck with that motherboard. The 24 pin is curved but it is 15cm on the short side and 20cm on the long side so 22cm should work fine.
Xaeons
30
Ahh sorry I wasn't clear, I meant 22cm (220mm) for the EPS/SFX 12V 8PIN as indicated in Nouvolo website
Based on my pictures above, 12cm (120mm) for the 24pin is close enough without too much slack.
EDIT: Ordered custom cables from Ray with the following details:
customized corsair full modular psu cables sleeved silver plated cables MOD
old version sf600
1x 24pin - 120mm
1x CPU8P - 220mm
1x GPU8P - 230mm
1xsata 2headers - 160mm+20mm
unsleeved - white
2,695
2,825
old version sf600
1x 24pin - 120mm
1x CPU8P - 220mm
1x GPU8P - 230mm
unsleeved - white
Here is a picture of the cables installed. Both the EPS and PCI 6+2 are 265mm and like I said the 24 pin is 150mm on one side and 200mm on the other.
Xaeons
30
Suggest not to fold the cable behind the 24pin and PSU, it is bending the 24pin connector
The one connected to the motherboard? No biggie, I have since corrected that, just wasn't able to take a pic. These were from when I first started building on the case and thought I'd take pictures to document it.
Thanks!
Poblopuablo
816
465
The threads are standard M3
I ordered some m3 screws and standoffs for my mod, I'm just trying them now and they don't fit. Can you please confirm, are the thumbscrews (that hold the glass to the side) m3? It's possible that Amazon sent me the wrong size since it's not listed on the package what size these are, but the threads on my "m3" screws and standoffs do not match the threads on the thumbscrews.
Xaeons
30
Damn I thought a 120mm AIO would fit at the bottom. I am still thinking if I would get a Big Shuriken 3 or an AIO for my 3600 (don't like tophats, so the only choice is a 645LT which is sold out I think)
Would love to use an L12s but my ram sticks are kinda tall (Trident Z)
Poblopuablo
816
465
TL;DR: 120mm aio does not fit, (unless you mod your case and possibly your aio, and even then it may not)
@Xaeons my case is modded and I don't have a stock aio. I have a custom radiator on an aio block/pump that I cut the tubes from, re-filled with pre-mixed fluid (not the stuff that it came with)and then re-sealed the aio. I'm not even sure how well it will work yet. In all honesty, with my luck, I just wasted ~$90 on my aio mod. Lol.
Also, I have to use standoffs for the panels since it won't fit due the the end tanks being too large for the case.
Xaeons
30
If that's the case, could I just buy a generic 92mm radiator, a pump block, 90 degree fittings, some tubing, and an a9x14?
I saw an Asetek 645LT in Overclockers UK and the cost of that + shipping to asia costs almost as much as a locally sold h100i or Kraken X52 (and if I'd go that route I'd have to buy a tophat)
Poblopuablo
816
465
A 92mm aio can fit. With minimal, maybe even no modding (PSU might need to be raised a little)
Edit: new 92mm mounting holes may be needed.
chyll2
431
362
if you will be using AIO, I suggest do what @Poblopuablo did. Still cut-out the bottom (depends on you what the pattern will be, and yes, you need 92mm mounting holes as well for asetek 645). The current vent pattern is just to restrictive for airflow.
Reactions: Poblopuablo
