Production No more sandwich. W19. Up to 360AIO and custom loop. Up to full size 3-slot gpu. DDC pump. Ready for uncompromise watercooled in 10.5L console case.
Which kind of case to send to production first?
  • Total voters
  • Poll closed .
Houdini
154
81
Why not? It's a slightly overlength (default lenght is 10cm), but it doesn't affect anything. The distance between screw holes should be 108mm.
Thanks for the answer.
I wasn't sure if straight is ok or if the riser needs to be left-angled/right-angled/reversed/etc..
Ok cool then I will measure the screw hole distance when I receive it and keep the riser if it fits.
Can we expect to receive the case before August?
Houdini
154
81
Hey @SammyXXM , I've got another question. The screenshot is the front view of the case.
How much space is there on the backside of the GPU PCB to the sidewall? Thanks
SammyXXM
230
387
anthecase.com
It is required to subtract the thickness of the frame and small components from the calipers data, the total space is ~ 7 mm. Measured on an A4000 from the PCB surface.
Reactions: idgas and Houdini
idgas
Thanks for the detailed measurements. It goes without saying, but no active backplates allowed. 😆
Have others’ cases shipped? My LOBOs arrive today, and my other parts are ready as well.
Reactions: sos and Houdini
Houdini
154
81
Yes haha I just wanted to see if maybe some copper plate or so can be added.
LOBO is very interesting! Please keep me/us updated on how it performs in the W19
SammyXXM
230
387
anthecase.com
LoBo is a great product. I've been designed own pump/waterblock combo for W19/D17, but stopped after finded LoBo's thread, hehe. Difference was been only 2 mm tall and flow route.
Cheezo
52
24
Received the case today.
The case is quite solid, weighs about 3.5kg (i have stainless steel one) and feels very strong inside - the insides panels do not bend and everything sits very firmly. I have not been able to build pc yet, because my EKWB 240 basic doesn't fit :(
Cons: the magnets on the panels fall off pretty quickly, @SammyXXM say he will replace it.
I think I'll hold it until I get to the custom water-cooled build.
SammyXXM
230
387
anthecase.com
Any shipping update?
Will the magnets be already fixed on those cases?
Shipping was delayed to solve the problem with a magnets fixing. The glue has been replaced and now shows good strength. I need doing some more tests to make shure everything is ok. Shipping will start on Wednesday if test will be passed successfully
Poplarfoam
Hi, is everything in the shop in stock and ready to ship? I’d like to purchase a stainless frame, sides, stand and reservoir.
