is the top of the case(in desktop orientation) of mesh like material kind of like the t1? Just curious based off your profile pic. Only cause kinda like the effect of the cpu block glow through the t1 mesh lol
There is 270° riser:It looks to me that in this orientation there isn't any room for typical gpu pci-e connectors on the outside of the card.
For cpu + gpu watercooling maybe allowing for a 280mm radiator would be enough?
I think he means there is no space for the PCIe power connector which comes out from the top on most cards. At least from your pictures it looks that the case can only support that specific RTX FE card you put in there?
There is no room under GPU for fullcover fitting. Adding 30mm will increase the case height to over 410mm. But i think you can use this solution:https://preview.redd.it/kvn0jgdv93o...bp&s=9ed008ce0f0552241587a032531b5bd8bc174d7d
So, if we have a slightly shorter GPU, we can fit a mini pump/res in there, as in the FormD T1. Can you add a mounting place for a mini pump/res? (Beside the GPU)
Also will be super useful for custom loops
how's thickness of side cover panels? it seems to be supported sfx psu, if it'll be choosen 62mm+3mm and cut 1mm inside of that panel...isn't it? ?
I just thought about the system should be got enough power having 240mm water cooling with 3 slot GPU
That's not exactly WHAT I meant... If we have a SHORTER GPU, we might have the room to put the mini pump/res to the right of the GPU. (If you even know what I mean)There is no room under GPU for fullcover fitting. Adding 30mm will increase the case height to over 410mm. But i think you can use this solution:
Alphacool NexXxos GPX Pro Solo
Or you can wait my next project that turns a case into a piece of art . "Dark Tower Pro DX1000"Dual 560mm radiators
ought to be enough for anybody,any GPU compatible, DDC dual pump, SFX PSU etc. at 19L. but this is not quite SFF.
Ok i see. But why?That's not exactly WHAT I meant... If we have a SHORTER GPU, we might have the room to put the mini pump/res to the right of the GPU. (If you even know what I mean)
Plus, the Eisstation 40 DC-LT and the DC-LT 2600rpm pump together only have a thickness of ~50mm, so they will most DEFINITELY work if there is a shorter GPU.
Yes, you guessed it!Ooh wait. What about a 360mm rad+fans with a mini-itx GPU?
