Production No more sandwich. W19. Up to 360AIO and custom loop. Up to full size 3-slot gpu. DDC pump. Ready for uncompromise watercooled in 10.5L console case.
Which kind of case to send to production first?
  • Total voters
  • Poll closed .
SammyXXM
230
387
anthecase.com
So, now it's version with AIO compatibility, right? i can fit for ex 240aio + RTX 3080/3090FE?
And about PSU, on silverstone render i can't see on/off button. My Corsair SF750 have it.
The power supply unit equipped with a power button must be turned on before installation. Yes, you can fit 240 AIO along with 3090. But, keep in mind, the case developed for fully liquid cooling. So, optimal case usege is 360 rad full custom loop.
Cheezo
52
24
Yep, that's nice. I wanna make custom loop but in future, for now i can do AIO + air GPU.
thelaughingman
1,413
1,566
Pre-order will start tomorrow at anthecase.com. PM me to get voucher discount code.
browsing the website as of writing - navigation is not intuitive to say the least and there's no info on the product page -further improvements are definitely needed IMO.
in terms of SKUs - is the starter edition just the aluminium frame + fabric mesh? I assume so since it is the same price: 163 + 35 = 198
Reactions: DrHudacris
SammyXXM
230
387
anthecase.com
The site is still under construction, i just need to enable people to pre-order.
The starter edition has mirrored stainless steel frame.
Cheezo
52
24
So it's version from main post:
W19
External dimensions: (W x H x D) 66 mm x 440 mm x 345 mm.
Support AIO up to 360 mm and custom loop with radiator thickness of up to 39 mm (with 25mm fan).
supported two DDC pump (with dual top).
CPU coolers up to 47 mm high.
GPU size up to 330x130x63 (in 240rad mode or air cooling mode) or 215x130x63 (in 360rad mode).
Mini-ITX mobo.
2x2,5" SSD.
SFX and SFX-L PSU.
And mirrored stainless steel, right?
Houdini
157
83
Can you also put on website what will be included in the package? (Standoffs, GPU riser cable, power extension cord, ...)?
thelaughingman
1,413
1,566
okay so just to sum up:
  • Gunmetal is aluminium frame
  • Aluminium is aluminium frame
  • Starter edition is mirrored stainless steel frame
correct?
just want to make sure people get what they actually want. cheers!
Reactions: SammyXXM
Houdini
157
83
I wondered if the holes in the front help with airflow..because the case is designed with direct air throughflow as you say.
And it could look super clean and sleek without the front holes.
I know you're close to or even in production already 😅
SammyXXM
230
387
anthecase.com
This helps when using a GPU with a standard air cooler blowing hot air in all directions. This holes gives an additional -2 ° C. In the case of liquid or the new 30XX FE cooling, this is of course useless.
Cheezo
52
24
Soo i pull the trigger and order starter edition hehe.
I think assemble so tight case will be pain in ass, but i hope it will be nice.
Houdini
157
83
Mined some more bitcoin, purchased the remaining coins and pulled the trigger on the starter edition too!
I'm so excited
