Sound good, maybe the golden standard for RX5700? Is it correct, that general the strix series allows to use 120x25 fans below the de-shrouded one? From pictures I've seen it shall possible (with/without ?) removing some tabs at cooler (concrete it was a GForce). Also I'm happy that's possible even with full front I/O. Do you have any progress with respect to remove the shroud (even with more pictures)?... Rx 5700xt Strix fitted easily when you put it though the front first and slide it in place afterwards. Rests nicely on the front i/o cables.
Addendum:
If i spin the idea like this, almost every < 300mm AIB (e.g. Powercolor Red Dragon 5700XT) should fit without shroud; the question would be how easy it is to remove the shrout and how the 120x25 would fit perfectly underneath it. Isn't it?
