welp, still waiting on an email, but ill be as patient as i can
i cant help you with 2 and 3, but with 1 i can help. Fans is your option, but get ones that are pretty quiet and pretty good, i would buy noctua fans, but they can get expensive so just look around wich fans fit with your clearance. And i would recommend to put it as intake, because when the fans on the GPU turn on, and your fans beneath it are as exhaust, they will fight for the air and wont be good at all, and as intake it will cool the GPU without its fans turning, and so helping your GPU with lower temps. And as for 2,3 i would recommend going a few pages back where a lot of discusion was about the cooler, and otherwise if anyone else can help with that, would also be greatI am going to transfer my hardware into the M1 and read this thread for 2 months now. I use a ryzen 7 2700x on an ASrock Fatal1ty B450 Gaming-ITX/ac and rtx 2070 Ventus. I have a few questions and I hope someone can help me out:
1. Which fans do you use under the gpu and should they be oriented as exhaust or intake?
2. Will the C14 fit on the mainbord or interfere with the VRMs?
3. I´m still unsure wether to use a U9S or the C14. I already understood that the C14S is the better performer, but I am not sure which fans to use and how. I would like to keep the PSU in the standard position to keep its temps low and the fan quiet. So as I understood there are several options and I wonder what works best.
- 92 mm in the back, 120mm under the c14
-92mm in the back, 120mm under the c14, 1 or 2 x120mm slim fans on the side bracket
-92 mm in the back, 1 or 2 x120mm slim fans on the side bracket.
Is there any noise that is created by the air passing through the side panel? I experiencing it in the kolink rocket I am using at the Moment with th GPU fans creating such noise. If that is the same on the M1, I would choose the U9S.
I really appreaciate the work you all put into testing and then sharing your results.
Any news on when we can order separate panels?
from the discord "panels and most other accessories won't be available for at least a couple more months " ...
I believe the plan is for a full glass side window.
@lordzorg for your new window panel, so hopefully they release it quickly
yeah, i know, but i found out about the panel thing later, but ill make it more streamlined next timeIn the future, try multi-quoting several users posts instead of making 5 different posts. Just like I did in this post, with your own 5 different posts
The new feet will work with the old cases, they just need different screws. The V6+ screw holes for the feet are M4 threaded, whereas <=V5 are M3 threaded. The M3 screws used with the <=V5 feet are too small for the new feet.That's unfortunate. The circular feet were the only part I didn't like about it.
Could @Necere confirm that the new square feet will not fit on older versions of the m1?
I plan on getting that along with the replacement front io kit
M1 Front I/O Kit
Description ***This part is already included with M1 V6 and later*** Replacement M1 V6 front I/O module. Backward compatible with all versions of the M1. Includes the following: 2x USB Type A ports (requires 19 pin motherboard header) 1x USB Type C port (requires 20 pin Type E/Key-A header; see...ncases.com
Wow, I finally received the "Shipping update for order #" email yesterday night and today it's already been processed by Canada Customs in Richmond, B.C. and is now with Canada Post to deliver to me in Ottawa, Ontario. The delivery estimate is 1 to 12 business days which is very vague, but possibly understandable given how busy shipping is at this time of year and the fact that I paid for the least expensive shipping option. Maybe it will be driven across Canada instead of flown. I'll post an update about any fees I have to pay.
Mine too is in Richmond, I hope I'll get it soon because I live in Nelson, BC! Did you have to pay customs fees?I live down the road from you in Toronto, you'll have it by next week
Looking forward to hearing what the customs will be as I'm in Montreal myself. May I ask when you guys ordered?
