See the discussion starting here and going on to the next page. Seems like there may be some subtle difference between the 3080 and 3090 versions of the Trinity that isn't reflected in the specs.Hi, I'm building the V6 + 3080 rig, and now trying to understand which GPU I can get.
The list in the header shows that Zotac RTX 3090 Trinity fits with "difficult installation", and 3080 with the same dimensions doesn't. It's a list not updated yet, or it's confirmed "not fits"? I saw V6 with Trinity here - - looks like it fits (barely).
Zotac Holo 3080 fits, by the list, even w/o "difficult installation", while has larger dimensions (higher and thicker).
Which Zotac better fits the Ncaase?..
Well I didn't think it would fit, but a EVGA RTX 3080 FTW3 Ultra model does indeed fit in there. Even managed to keep the front IO panel connectors there. Just barely. I had to angle the front of the card into the small opening in the front of the case and come in at a slight diagonal angle and do some contortionism, but I was able to fit this giant card in there. There's no space for bottom fans as a result. I was able to remove it and put it back in as well though that was a royal pain in the rear to do.
It also required 3x 180 degree PCIE8 connectors and still a bit of pushing down on the card's front end to angle it down enough to close the case. I could probably shave some foam off of the backs of the 3x 180 degree PCIE8 connectors to keep from having to do that. The side closes successfully though after pushing down on the front end of the card with the foam a bit.
I used these if anyone's curious Amazon product, had to buy 3 packs since each set only has 1 usable, and I had to buy 6 and return 3 because they mounted the wrong PCIE sockets on 3 of them). Anyways with a Ryzen 5800x and this card and a NZXT x53 Kraken in there there's not much space for air. I did stick a Noctua 92mm fan on the rear but I feel like the right side of the case gets pretty hot. and I would like to put a front fan on the case. I may have to drill holes in the front frame panel (where a 2.5" HD or Slim DVD drive would normally go) to do so. Would nCase consider perforating this area in the future with holes or slits to help facilitate mounting a front fan that can blow past the PSU/CPU area from front to back?
I order the 180 degree PCIE8 connectors. Do they affect the stability of the power supply?Well I didn't think it would fit, but a EVGA RTX 3080 FTW3 Ultra model does indeed fit in there. Even managed to keep the front IO panel connectors there. Just barely. I had to angle the front of the card into the small opening in the front of the case and come in at a slight diagonal angle and do some contortionism, but I was able to fit this giant card in there. There's no space for bottom fans as a result.
It also required 3x 180 degree PCIE8 connectors and still a bit of pushing down on the card's front end to angle it down enough to close the case. I could probably shave some foam off of the backs of the 3x 180 degree PCIE8 connectors.
I used these if anyone's curious Amazon product, had to buy 3 packs since each set only has 1 usable, and I had to buy 6 and return 3 because they mounted the wrong PCIE sockets on 3 of them). Anyways with a Ryzen 5800x and this card and a NZXT x53 Kraken in there there's not much space for air. I did stick a Noctua 92mm fan on the rear but I feel like the right side of the case gets pretty hot. and I would like to put a front fan on the case. I may have to drill holes in the front frame panel to do so. Would nCase consider perforating this area in the future with holes or slits to help facilitate mounting a front fan that can blow past the PSU/CPU area from front to back?
I checked the card out and unfortunately the Sapphire Nitro + SE Edition is to long for Ncase M1. It wont fit.
I got the tip to check out the Gigabyte 6800 Aorus versions. Those are 3 slot, but shorter. Or else I will wait till February 2021 for Nvidia 3070 TI.
It's just, this generation GPU cards are huge and don't have great designs in my opinion.
Thanks, indeed it doesn’t and although the 3090 TUF OC will fit fine as is, it does not fit with a water lock on. I ended up returning it (will be dropping it off today for a refund) and I have a PNY 3090 on order that I will use an EKWB waterblock on instead.I think it won't fit, that water block is 148mm in height.
are you going for a dual radiator build?Thanks, indeed it doesn’t and although the 3090 TUF OC will fit fine as is, it does not fit with a water lock on. I ended up returning it (will be dropping it off today for a refund) and I have a PNY 3090 on order that I will use an EKWB waterblock on instead.
Frankly I don't think so. My plan A is trying to fit 6800xt red devil in Ncase, but it won't fit at all after doing some research. So I changed red devil to 6800xt Nitro+ with my plan B. I've been measured for weeks and highly possible 6800xt Nitro+ would fit tight. I already got the GPU in my hand and the length of the GPU is actually 305mm, not 310mm. My Ncase will deliver this week and I will find out. The worst situation is to remove the GPU fans. Wish me luck tho.
Yes, hopefully it will work out. I‘m returning the Asus TUF OC tomorrow and the waterblock for it, and I’m waiting for the PNY and it’s waterblock along with some more bits. I’m hoping to have all parts in hand by middle next week so I can finally start the build. Currently using the old trusty air cooled system in my Ncase v5are you going for a dual radiator build?
when did you place your order for the case? and what shipping option did you choose?So my Ncase has arrived today,
I have the v1 Ncase on hand and a Holo coming soon, a visual inspection of the case suggest either a deshroud is done or part of the slope at the end of the GPU's shroud needs a bit of sanding down. Will follow up this weekend.Hi, I'm building the V6 + 3080 rig, and now trying to understand which GPU I can get.
So even the Alphacool reference block for thr 6800/6800 xt wont fit the M1 with its 130 x 262,5 x 24,5 .For anyone who's interested in water cooling 6800xt, here is the conclusion based on my experience:
1. The only possible option (for now) is reference design pcb + ekwb velocity block + 90 degree customized cnc plexi terminal.
In my current build, I'm using a 90 degree terminal for my 5700xt red devil and it's about 9mm thick. For 6800xt reference design, this number can be loosened to 11~12mm.
2. Based on the measurement above, the space for terminal is only 13mm. This number should be pretty accurate as I calculated based on the width of my 5700xt red devil water block without terminal.
That being said, none of the manufactures can provide a usable waterblock for ncase m1 because the G1/4 hole is 11.8mm, they can't make a regular terminal to include a G1/4 for only 13mm unless they use "uni-body" style copper instead of plexi and screws.
3. On top of that, the slimmest AIB 6800xt card is about 145mm wide (Sapphire nitro+ and red devil). As for my 5700xt red devil, this number is 143 and I have to keep my customized terminal to be 9mm thick. So if you consider AIB 6800xt, you need to make a 7mm thick terminal. It's doable, but plexi can't handle the pressure, you will have to use copper. Also you need to wait EKWB or other manufactures to provide the respective AIB waterblock.
Good luck.
I don't know how they measured the 130mm width, weird. It's either EKWB provided a wrong measurement or Alphacool's waterblock won't cover the whole GPU body. We can't tell until someone gets them and measures them.So even the Alphacool reference block for thr 6800/6800 xt wont fit the M1 with its 130 x 262,5 x 24,5 .
Do you know someone who can make a 90 degree customized cnc plexi terminal?
No, they are solid. At least on my 5700XT. I pushed it to about 290W, no problem at all.I order the 180 degree PCIE8 connectors. Do they affect the stability of the power supply?
