NCASE M1 V6 GPU Compatibility List
Ca11idus
88
58
www.heatware.com
can anyone cofirm good fit without front panel IO and deshrouded?
GIGABYTE GeForce RTX 4070 Ti SUPER Gaming OC 16G (https://geizhals.de/gigabyte-geforc...-oc-16g-gv-n407tsgaming-oc-16gd-a3097288.html)
or a
ASUS ProArt GeForce RTX 4080 SUPER OC, PROART-RTX4080S-O16G (https://geizhals.de/asus-proart-gef....html?hloc=at&hloc=de&hloc=pl&hloc=uk&hloc=eu)
thank you very much!
The 4080 pro art fits:
NCase M1 RTX 4080 ProArt With I/O
NCase M1 RTX 4080 Super ProArt Without I/O
Reactions: 1349
morology
Just confirming that the Gigabyte 9070 non-XT card fits. I have an older M1 V2, unmodified, no fancy cables or cable management. I had to remove the front panel cover, front bottom feet, and front port assembly to get the card into the case - you'll have to angle the card in, and I needed the hole in the front of the case unobstructed to do it - but once it was in I was able to put the ports back.
The Gigabyte 9070 XT card is the same length and width, but listed as 6mm thicker. Looking at the end of the card in my case, I think the XT card could fit but it's going to be right up on the cable coming out of the front panel for the dual USB ports. See attached bad picture.
The Reaper is shorter and should fit no problem. The Sapphire Pulse 9070 (non-XT) should also fit easily.
Reactions: kikimaru024
j8ming
只是确认 Gigabyte 9070 非 XT 卡是否合适。我有一台较旧的 M1 V2,未经改装,没有花哨的电缆或电缆管理。我必须卸下前面板盖、前底脚和前端口组件才能将卡放入机箱中 - 您必须将卡倾斜,并且我需要机箱前面的孔畅通无阻才能做到这一点 - 但一旦它进去,我就可以把端口放回去。
Gigabyte 9070 XT 卡的长度和宽度相同,但厚度比后者厚 6 毫米。看看我的机箱中的卡尾部,我认为 XT 卡可以装进去,但它会正好位于从前面板引出的双 USB 端口电缆上。请参阅所附的不良图片。
[媒体=imgur]xufKoMk[/媒体]
Reaper 较短,应该没问题。Sapphire Pulse 9070(非 XT)也应该很容易安装。
连接电源线后可以关闭盖子吗?
MOD EDIT: "Can I close the lid after connecting the power cord?"
phineasfox
I would assume if the I/O ports were removed the XT would probably fit better?
Reactions: hrh_ginsterbusch
morology
连接电源线后可以关闭盖子吗?
Mine is closed. I have the stock panels and the stock power supply cables from a Corsair SF600. Everything fits.
One problem I did encounter is that the USB front port cable, if not routed well, will hit the GPU fans and be noisy. So you have to be careful with that.
It looks that way, since the molded assembly there would be gone.
alecborlan
I'm struggling to figure out if I will be able to fit an ASROCK 9060 XT 16GB into my ncase M1. The card with is the potential problem. It is listed at 132mm. So I'm not sure if that 130mm (first 5mm at back corner) is going to be an issue or not. Anyone know if this card would fit or not?
