Completed Lone Industries L4
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
Here's a look inside the empty box.
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
I'll try to get some more images posted as soon as I can.
Some good news today! My manufacturer has some time now, and has started working on my order. :) I will be starting out with a very small batch of parts, so availability will be limited initially.
Awesome news!
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
What are those six holes for in the the upper right for? DC-DC Board?
Are the C14 AC input and hole for iFreilicht's RGB Vandal Button (power switch) still in these same positions?
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
Stacked 2.5 inch drive mounting points. As you can see, I try not to over engineer anything. ;) Including the holes is just done for convenience since it doesn't add to the cost of the case.
EDIT: This has changed in the production model.
Yes. The round hole is for any 16 mm switch.
Reactions: ricochet
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
So the HDPLEX 80W AC-DC Adapter would fit in on the inside front panel just next to these 2.5 inch drive mounting points?
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
Yes, but both will not fit at the same time. The 6x 2.5 inch drive mounting is a maximum, and maybe it's too misleading? With a 80W AC-DC at the front, there are other mounting options at the bottom of the case, or at the front and parallel to the motherboard. If you use a GPU with dual slot cooler, then the bottom mounts would be unusable.
Reactions: ricochet
stefan33
73
24
The 160w AC-DC version can fit inside without any discrete GPU?
And with discrete GPU impossible?
Thank you.
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
The 160W AC-DC will not fit in the bottom of the case.
The 160W AC-DC will physically fit at the front of the case. The problem is there isn't a DC-ATX that will fit with the 160W AC-DC. The old HDPLEX 160W DC-ATX (non direct plugin style) might work.
If someone wants to do this they're going to have to experiment a little.
stefan33
73
24
Ok, but if the 160W AC-DC will physically fit at the front of the case means that it can fit also with a graphic card. And the new HDPLEX 160W DC-ATX (direct plugin style) coul fit by this:
https://www.alibaba.com/product-detail/Black-Red-Sleeved-24Pin-ATX-Female_60579036587.html
What do you think?
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
What do you think?
Great idea, since I was using such an extension with my system it dawned on me yesterday when I installed my new HDPLEX combo as well that I could use this very same 24-pin ATX extension cable if I my next case was too low for the HDPLEX Direct-Plug.
Would it be harmful to lay/affix the Direct-plug on/by it's heatsink on a case... or maybe use a rubber standoff like they use for PSUs... thermal padding???
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
The story I was given was that the owner hired some help during the holidays, and that this individual shipped it to the wrong company. I'm not sure if this is the truth, but I'm not going to worry about it. :)
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
Drawings confirmed, and purchase order submitted for first tiny batch of L4 parts. Debating whether to include expansion slot covers.
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
I say save the money and avoid the headache as most of us have one or two of those laying around!!! ;-)
Reactions: janas19
