Lian Li/DAN A4-H2O
dondan
1,970
8,311
My first thought was: Ok, no 12900k. Meh. *researches application benchmarks about 12700k, 5950X etc. all over again*
Techpowerup: " Even when watercooled by our 360 mm AIO from Arctic, the temperature reached close to 100°C when fully loaded."
https://www.techpowerup.com/review/intel-core-i9-12900k-alder-lake-12th-gen/24.html
The problem is not the case it is the fact that a 240 AIO can't cool a 12900k under heavy load. What use case do you have? Handbreak, Keyshot or what other CPU intensive load? Another option could be undervolting or Power Limiting the 12900k.
hrh_ginsterbusch
1,089
459
Germany
wp-devil.com
We are aware. Hence just "thermal issues", NOT "thermal issues with the case". Thus also the though experiment (in reaction to other comments in this thread). As you may have or have not read, I already mentioned power limiting as an option, too.
Our particular use case / scenario is: Audio / Video editing, and streaming (ie. primarly DJing). Specifically, doing all that on CPU, because of all the funny driver issues with both AMD (OBS + AMD GPU encoding apparently is the worst choice, but Linux support is much much better) and NVidia (lets not open that can of worms).
A secondary use case is running multiple VMs and browsers during development. We've been doing a lot of really heavy-load backend development in the last few years, and the more CPU power, the merrier.
Third use case obviously is the reach for perfection ;)
cu, w0lf.
ps: Originally I wanted to reply: lets maybe wait on the 12900 non-k, but the tests I could dig up so far look very.. naaaah. As in: Making the 12700k look much better.
Reactions: Merry Monkey
Fa5en
45
Denmark
Great looking case that just about fulfill my needs. But one question, i have no USB 3.1 header on my MB (Asus B360i Strix) but there's one on the rear i/o. Can i use this as an adapter:
dondan
1,970
8,311
Not good because the back fan is too close to the PSU every other 3090 should be fine.
dreaming of sff
loving the look of this case, just a question, is the front i/o swappable to the other side of the case? would like to put my pc on my left rather than my right.
TheKDub
Any difference in mounting the fans in push or pull?
There shouldn't be much difference in push or pull. A benefit of a pull configuration would be easier cleaning of the radiator, since the dust will be exposed, rather than sandwiched between it and the fans.
If you meant intake vs exhaust, intake would likely result in higher GPU temps, lower CPU temps. Exhaust would result in the opposite.
Given the PSU exhausts into the radiator, I'd think having the radiator fans also as an exhaust would be the best idea, that way you're not fighting the PSU fan.
Reactions: DrHudacris
dondan
1,970
8,311
Sry this isn't possible.
Wow, who is shipping already?
He does come from Taiwan. Maybe he directly ordered it from LianLi or it is available from taiwanese resellers.
Reactions: carpet3 and rfarmer
DavidN
27
