What are the screws on top for? They seem to be new.
I guess they're there for a reason, but IMO it looks nicer without them. Moving them to the sides is no option I guess?
Feature locked.
MOBO: Mini-DITX/Mini-ITX;
GPU: Up to 185 mm length, dual slot, low profile
Power entry: 12 mm 4 pin mini-din support, C6 power entry cutout
PSU: RPS-200 mounting
Fan: 2x 60 mm in GPU config
Final dimensions: 190 mm x 248 mm x 66 mm, 3.1L
UHP-200 feature dropped. Double checked the dimensions and the case needed to be 205 mm deep to accomodate it, which puts it too big at 3.45L.
direct image link
Possible build Configurations:
1. SUPER APU: RPS-200, PLUGin-200X, Black Ridge 47mm cooler with 120mm slim fan, VLP RAM,
2. OLD SCHOOL MEDIA: RPS-200, PLUGin-160, Noctua L9, x16 PCIe to NVME adapter, 2X 2.5 HDD
3. LIGHT GAMING BOX: Mini-box 160XT Kit, Cryorig C7/L9, Li-HEAT short PCIe riser, LP GPU (GTX 1650, 1050 Ti)
It does almost seem silly that the internal PSU package, which can support CPU only, comes with a more powerful PSU than the external package that must power twice as much.For the kickstarter campaign, I am thinking of three packages:
1. Case only, choice of vandal switch
2. GPU ready, includes 160W brick and dcdc unit
3. Internal psu ready, includes RPS-200 and 160w dcdc.
The other question is if there is any desire for a 120W max internal unit? It is $25 cheaper than 200w but I feel like it wouldn't be popular.
Do you still offer a 120w plug in unit? Would the combination of 120w ACDC and 120w DCDC be more than $25 cheaper?
This new case is perfect for those like myself who want to utilize it as very small, a low power pfSense router build (that supports pcie network cards). My setup would consist of an i3-6100T (35w), Noctua NH-l9i, 120gb m.2 ssd, and a low profile pcie Intel i350 dual nic card. Personally, I would love the 120w option as I don't believe my use case would need anything more.
Looking forward to your kickstarter campaign, as I will definitely be supporting this project!
Excellent work on the Pure Mk2 case!
forms.gle
Says I need permission to view @ThehackHey guys.
I made a survey to get some answers on preparing for this kickstarter. Please take it here:
Pure Mk2 Kickstarter Survey
Please complete this form. Choose the answer that best fits your response. Some of the information gathered from this form may be used to plan and develop future products.forms.gle
