Cooling ID-Cooling IS-47K 47mm 6-heatpipe cooler with 92x15mm fan - Black Ridge alternative?
birdsliveoutthere
25
I purchased this cooler on Amazon for use in my Dan A4 v1/Ryzen 3700x build to replace the Noctua L9a (with shroud) I have been using. I used the Noctua backplate and swapped the fan to a spare NF-A9x14 PWM, oriented to blow towards the motherboard (the included fan can not be flipped, the blades will hit the fins). Temps rose quickly to +90C in prime95, which I attributed to the picture above. The bracket stripped when I was securing it, not allowing adequate pressure against the CPU. The mounting screw wasn't cross threaded, I think I received a dud.
Thehack
Creator
Mar 6, 2016
2,818
3,674
J-hackcompany.com
Yikes. If you're in USA, give me a PM and I can hook you up with a fix.
Here is a sample of the IS-60 EVO.
Fan looks sweet.
billabong2606
25
Fan looks sweet.
Iirc, the fan in this is supposed to be ARGB, isn't it? Would you be able to take a pic of it when turned on? Kinda thinking of getting just the fans to replace my non-RGB ID-Cooling NO-12015 fan that I used on my deshrouded GPU.
Thehack
Creator
Mar 6, 2016
2,818
3,674
J-hackcompany.com
Yes it is argb. Unfortunately I don't have my desktop available at the moment. It is in storage while I deal with some stuff.
Poblopuablo
816
465
Silverstone has a slim argb 120mm fan. Not as sexy as this one, but still an option. Or maybe go with a phanteks halos argb ring.
billabong2606
25
Did you mean this one? Seems a good alternative to the ID-Cooling ARGB fan, but I don't think it's available where I'm from, at least when I searched for it the last time. Thanks for the suggestion tho :)
birdsliveoutthere
25
Fan looks sweet.
Thanks for the offer, I would have taken you up on that but I returned it to Amazon. If I had enough room in the case to do a push/pull configuration and the bracket wasn't broken, I think this cooler would have been a good option. I've decided to go the FormD T1/liquid CPU cooling route.
soyboy
As someone who is swapping out my Noctua L9A for the IS47K - what would every suggest my set up be in terms of mounting? I'm already going to try and reverse the fan direction but not sure if I should use the stock mounting solution or the hardware from my L9A setup. Would appreciate any help as I have a K39 case and it is very annoying to have to undo everything so I would prefer to do only have to take it apart once! Thanks
scatterforce
411
325
Use the Noctua back plate. The IS47K has issues with proper mounting pressure; using a good backplate will help fix the problem.
Tuscany
159
63
When you finish the change, please do tell what is the outcome.
Currently wondering between staying with Wraith Stealth, the Noctua and the IS47K. So any additional hands-on feedback will be valuable.
soyboy
I did not do any stress testing on my noctua as I was in a rush but running the IS47K is about 28-30C on idle and 60C on prime95 - so looks good so far!
soyboy
I also decided to use my Noctua fan as when I flipped the stock fan there seemed to be interference between the fans and the heat fins.
soyboy
After about 30 minutes of Prime95 on Small FFTs it got to a maximum of 69 C according to HWInfo and 35 C minimum.
2,201
2,225
It's great that you're posting results as you're testing, but please use the edit button rather than posting five times in a row in the same thread. It's down next to the Report button on the lower left of the post, or hidden behind the [...] menu in the same spot if you're on mobile.
archagon
80
27
To be fair to soyboy, I don't think I actually had an Edit button until my first few posts... or maybe I just suck at looking. (I really looked!)
Reactions: soyboy
Tuscany
159
63
What is your setup, actually? What CPU and what case?
This will put the results in perspective.
