Firstly, thank you all for the feedback.
I will make sure to go through all of posts in these few days, and answer individual questions left unanswered in this post.
The purpose of this post is to move the general design forward, because I may be locking in a design with a manufacturer and ordering a prototype this coming week.
Overwhelmingly, people have voiced that:
- the vinyl strip is a no go
- the handle is not needed for such a small case
So I have removed those.
Now, I pose another question:
What hole layout do you believe to be the best appearance wise?
Of note:
#1 is the original, with the vinyl strip and handle holes removed
#2 and #3
Both feature full-length side panel holes. This comes with a trade-off. Looking from the outside, you will see parts of the PSU and the SSD on the other side. Also, a lot more wiring from the PSU will show through. The upside is that there may be heat dissipation advantages, though this claim is untested.
#3 also feature full-length top holes, which I believe to be purely cosmetic and make marginal difference in heat dissipation.
#4 feature full-length top holes and a moderate increase to side holes compared to #1. Looking from the outside perpendicularly, the top of the SSD is just barely covered. The PSU is fully covered. The untested heat dissipation advantage that the full-length panel is definitely absent here.
I do personally have a favorite amongst these 4 options. But I would like to have an unbiased discussion and hear your feedback first.
Vote here:
http://www.strawpoll.me/10040820
