Still, comparing 8010 fans' CFM to 4020 fans, 8010 fans will comfortably push the amount of air that 4020 fans struggle to.
Static pressure on a 10mm thick fan would be pretty low though, plus the air has to make a 90 degree turn.
The 80mm fan can only be 10mm thick. Yes, it is quite restricting, but it is the only way to enable that option while keeping the case at 3.99L
While I do not have the exact answers right now, the longterm plan is to have high enough Orders to make it OEM. (Note that if you look at the Venn Diagram, the most probable way to reach the center is using the Flex 80mm)
I just figured that no matter how/when that happens, it's good to have the space there right now (on the contrary, the extra length was not really used and I foresee it to continue not be used, as I explained in [H] - there's no incentive to for manus to make a 180>X>170 gpu).
I'm getting close to ordering a metal prototype, so I might just do that, mod my Flex and use my own machine as a longterm study.
Good call on the legal stuff though, it is something that I will eventually have to look into.
Is there even a single 80x10 fan available in retail?[...]
As Aibo said, maybe this isn't as great of a solution as we might think.
- GTX 970: 3 <170mm; 5 <180 (1 ASUS, 2 Gigabyte; 1 Inno3D, 1 KFA²)
- GTX 960: 2 <170mm; 9 <180 (2 ASUS; 3 EVGA, 2 Inno3D, 2 Zotac)
- GTX 950: 1 <170mm; 4 <180 (1 MSI; 1 ASUS, 1 EVGA, 1 Zotac)
- GTX 750Ti: 13 <170mm; 13 <180 (No difference here, great!)
I also highly doubt that our small run cases will incentivise GPU manufacturers to keep their cards at 170mm.
Really, if its around 4.2L, I do not see this being a big issue as I feel this potentially could be the Ncase of 4L cases due to flexibility of configuration should you allow for up to 180mm gpus.
Thanks for the vote of confidence. I do have the marketing in the back of my mind, and I tried trace the history/strategy of the M1 before.
I remember at their first Indiegogo campaign where they asked for $8000 for their first prototype, they already sorted out their manufacturing source and finalized design - two crucial things that I am in the process of doing, but have not completed.
So I know there's a lot of exposure-related things to be done, but I don't think I'm there yet. Close though.
I think our views on the maximum length of GPUs differ quite a bit. For me, I want to give the consumer as much choice as possible, and the reality is that there substantially more GPUs with a length of =<180mm than =<170mm.
Just a short list of the most significant examples:
I tried to fit the EVGA GTX 960 in a case with 180mm clearance but it wouldnt fit by a couple of mm, I measured the card at 183mm from the flat section of the metal bracket to the rear of the card.
EVGA state that it's a 173mm length card, but I reckon thats a mistake.
I presume the EVGA GTX 950 is also the same length.
From these picture, it looks like the shroud is longer than the PCB, can you confirm this? Maybe that's the length they measured.
If so, one could still fit this GPU by modding the shroud.
It would be a shame if it was that long, the I/O and exhaust are extremely nice for small cases.
If it's just the shroud, you can file them away, i guess
Yes the shroud sticks out beyond the pcb by about 10mm. I will confirm tomorrow when I'm back home.
That's very true, not sure I would be willing to do that though!
Also, since it's just a GTX 950.. Perhaps you can just use it without shroud![]()
If you want to file it, just make sure you don't end up like this guy: https://linustechtips.com/main/topic/561041-980ti-darwin-awards-help
Or don't attempt it at all!![]()
btw. I've got 2x 80mm 10,8mm Akasa Fans (Akasa AK-FN076) they are pretty got and easy to get. Maybe 10,8 to 10mm makes a different in terms of fitting...
Feel free to give me feedback on the handle and the vinyl strip + led color matching ideas. I'm all ears.
