We have nothing concrete to update the moment due to covid.Hey @Nouvolo ! do you have any news on restock for the v1.1? is there a v1.2/v2.0 in the works?
Thanks for the quick reply! And okay, that's pretty understandable :-) stay safeWe have nothing concrete to update the moment due to covid.
Also considering looking for something like a slim hat for top mounted exhaust fans too.
Oh wow, that's awesome. Have you tried printing them? I'm trying to find a reasonably priced source for 3d printing. Have you tried connecting the 2 halves together? Can that be done with super glue? thanks!I designed some 3D printable "slim stacks" for 25 and 15mm fans if you wanted to go that route: https://www.thingiverse.com/thing:3827933
How da hell do people get those cards?
Sorry no updates on restocking yet, you may want to consider the white version. ?@Nouvolo, Do you have any Steck updates for the fall. I know COVID is wrecking havoc, but just checking in.
A triple slot card case is in design at the moment but not sandwich style. Hope to get it ready for 2021.@Nouvolo any consideration for triple slot cards for v2?
smallformfactor.net
Shorter cables and install a bottom chassis fan will certainly help. Hey, with the all temps you mentioned, but you have not mentioned what CPU you are using... ? . If you are using the high powered CPUs (AMD 3800/3900X, Intel 10900K), low profile air cooler will not cut it, and you will need AIO. For the low tier CPUs you can use NH-L12S.Successfully transplanted the components of my old Inwin A1 plus PC to a Nouvolo Steck. Coming from an NZXT H210i to the A1 plus to this in a matter of 6 months is quite satisfying. Loving the smaller form factor in spite of the loss of RGB bling. Seen in the photo is the space previously occupied by my old case.
BTW, has anyone tried getting shorter, customized cables for their Stecks? How's your experience? I really want shorter cables for this case. I am also planning to upgrade from the stock Wraith Stealth cooler because it really cannot handle the smaller space, as the CPU gets as hot as 40-50C on idle and 80-90C under load. Should I get a Noctua L12s or get a stack unit and an AIO? Thanks and cheers
Thanks for the reply! BTW I use a Ryzen 5 3600 processor. I already decided to go with an AIO, hence I ordered a Stack Unit from Nouvolo since they are hard to avail locally. I'd probably go with IDCooling cause they're cheap but get the work done. Going with an L12s means I still have to replace my current RAM sticks with low profile ones though. I also have ordered PSU cables customized for this case from DreambigbyRay. Thanks for welcoming me to this thread!Shorter cables and install a bottom chassis fan will certainly help. Hey, with the all temps you mentioned, but you have not mentioned what CPU you are using... ? . If you are using the high powered CPUs (AMD 3800/3900X, Intel 10900K), low profile air cooler will not cut it, and you will need AIO. For the low tier CPUs you can use NH-L12S.
so clean! You can save some more space with Aquanaut tho ?Put some last pieces into this new build for my wife... i.e. leftovers. lol
