Power Supply HDPlex AC-DC and DC-DC combo
4,788
He said that the current third doesn't attach to anything anyways so it's not a big deal?
The C14 inlet has a ground terminal that can be attached to the chassis. Assuming it's not a dummy wire then if that is properly screwed to the metal case then the chassis should be grounded.
But it does not directly ground the AC-DC unit itself, if the unit is screwed to the case then it'd be grounded to the case, or through the motherboard if the mobo is grounded via the standoffs.
4,788
It's uncertain, I made a few suggestions based on my pre-production unit and he's looking into it.
cleveland
455
240
Thanks a lot for the hint. I'm on a desperate need of some 160w and 250w units to finish 4 builds for my office and can't wait much longer... time to go for the chinese stuff. :confused:
KMPKT
3,382
5,936
Last I spoke to Larry, it's a 300W internal brick now and will be paired with the new version of the DC-DC which will also be rated for 300W. I believe he's trying to revise the design to make it better able to respond to draw spikes as are customary with CPUs and GPUs.
4,788
Oh good, I was thinking it's getting confusing with all these mismatched wattages between the AC-DC and DC-ATX.
BirdofPrey
Standards Guru
Sep 3, 2015
797
493
Indeed. Unless they create a system where the motherboard is powered by a separate picoPSU style DC-DC PSU and everything else is powered off a different DC-DC PSU, it makes the most sense to me for each DC-DC PSU to have a matching AC-DC PSU
KMPKT
3,382
5,936
That will be the next product developed as far as I know. PCB for "everything else" with 19V output to a PICO style unit. Goodbye 24 and 8 pin power connectors <3
Reactions: confusis
BirdofPrey
Standards Guru
Sep 3, 2015
797
493
I've mentioned this before, but what I'd really love to see is a 3-400W AC-DC PSU (enough for a mid range CPU, mid to high range GPU and one or two drives) that only outputs 12VDC, then connects to the motherboard with a Pico style PSU, but have the pico PSU able to turn the AC-DC PSU on or off while still receiving a small amount of 12VDC standby power to convert to 5V Stand-By for the motherboard.
4,788
So the width has increased a bit to allow for more heatsinking. The final dimensions of the 300W AC-DC adapter are 62mm x 41mm x 146mm (WxHxL):
And Larry said I should be getting a review unit sometime in February so presumably retail release will be around the same timeframe.
vluft
programmer-at-arms
Jun 19, 2016
159
140
Hmm, think this makes it just too wide for the S4, I think? (with wide edge installed against narrow edge of case). Would need to be installed sideways. Not an issue for my build, thankfully, as I have the space, though will have to figure out mounting beyond just conductive taping to bezel I guess.
KMPKT
3,382
5,936
5mm too wide to fit in the bottom of the S4 mini. Originally I was thinking you could just sand off the fins to get width down, but I reckon this would be pretty tight. I wonder if cutting the inner portion of the S4 would create enough space.
Thehack
Creator
Mar 6, 2016
2,818
3,674
J-hackcompany.com
I am working on a Meanwell PSU build just like you describe. The Meanwell has very low standby power and has low no load power usage, in the 1-2w range. However. To use the standby feature the PICO has be to be pinned for it which most designs current do not. they only have 12V input.
aquelito
Piccolo PC
Feb 16, 2016
955
1,126
So the width has increased a bit to allow for more heatsinking. Here are the final dimensions of the 300W AC-DC adapter.
Thanks for the heads up ; can't start my next build without this one :(
4,788
It's probably the 250W, the 300W DC-ATX hasn't been released yet because the 300W AC-DC isn't ready yet.
Reactions: FreezingCode
