Power Supply Merging HDPlex AC-DC units (A PSU Experiment)
K2e2vin
i'm just winging this so got a question. how the power into the hdplex is a 6 wire plug should i run each wire to seperate post on the psu or can wire 3live wires to one live post 3 neutral to one neutral post or use all 3 posts ?
You can bind them together assuming the single wire can carry the current. The plug that HDPlex uses for the DC(brick) connector binds them together too.
james1976
so i got some 6pin minifit jr connectors aka 6 pin pcie i was going run one from the hdplex and mount the end in the case panel basicly it is just like a 6 pin gpu extension from the hdplex to rear case panel. then a male 6 pin molex with the 6 wires coming out of it to the ac-dc power unit. so would i put the 6 wires on the ac-dc unit on seperate posts ? what i mean 3 live wire to 3 v+ posts or could i put 3 wires on 1 v+ post? sorry i am haveing hard time asking this much easier to say then type out.
james1976
If a single post can handle the current, you can put all three wires on one post.
ok i guess i will use all 3 cause i got no idea just winging it and i can't find no info the only thing i know psu is meanwell se 600 24, it is 600 watt 24volt 25 amp
