Power Supply HDPlex 400W AC-DC Adapter
19NinetySix
53
Is this confirmed or rumor, I have seen posts saying it will be released during every month since August.
Directly from Larry like always.. I ask once a month then post on here.
Would you like to see the emails from the last few month? Would that confirm for you? Lol
Ive had an empty s4 mini for 5 month so I get your frustration. Just need to wait a little longer..
Said he would have a more acurate date next week but ETA is early november..
his email is on the website.
sparklepony
71
Can confirm he also told me early november.
They found a low voltage noise issue that was fixed last thursday. Production continues.
The waiting game is the hardest game :)
Untero
83
80
I wonder how the pipeline for such devices looks like.
Is that the same prototype getting reworked until it's functioning perfect or each major fix requires a new prototype.
@Kmpkt
Craig, have you had a lot of dynamo 360's before it came into production or just a few?
KMPKT
3,382
5,936
I went through two prototype boards and used the second as the basis for the final production unit.
Reactions: Untero
AMv8-1day
228
193
Well I just bought another dual CPU board while I'm waiting because yay eBay.
So now I have a 12x10" (305×254mm) SSI CEB board currently populated with a pair of E5-2667v2's, and a 12x13" (305×330mm) SSI EEB board because... $200 for 16 DIMMs and all the PCIe?
Can't get my hands on the 800W unit fast enough.
No way I'm going to be able to support cooling AND an ATX/SFX PSU.
Goatee
739
1,513
I assume the HDPLEX 400W AC-DC could be used to power a thin-itx board via the two pin on-board connector and a HDPLEX 400W HiFi DC-ATX at the same time? Those board take 19V inputs same as the DC-ATX,
I plan to just bring the board power out of the Molex 6PIN before it goes into the DC-ATX, then jump the DC-ATX to power one of @aquelito risers for the GPU?
Any issues / thoughts?
aquelito
Piccolo PC
Feb 16, 2016
955
1,126
If you stick to 19V, @Kmpkt Dynamo board is best suited for thin mini-itx applications ;)
If your board takes 12V input, then I would suggest going the 12V road.
Powering hardware is less "charted" but thanks to @Thehack, it's about to be fixed.
Reactions: NinoPecorino
Goatee
739
1,513
@aquelito I already have a HDPLEX 400W DC-ATX and will need near to 300W so it should suit the purpose, I assume my thinking is still correct?
Board only takes 19v, I could always power it seperately via a second brick, but where is the fun in that? :)
Windfall
2,117
1,584
Things I am waiting for:
1. Second coming of Jesus
2. HDPLEX 400w ACDC
3. Half Life 3
4. Star Citizen
Based on current events I am fairly certain #1 is happening first.
Numbers 1 and 3 will happen at the same moment, along with Despacito 2.
Skinz
26
I am still on the fence on whether or not this would be the right option for me. I'm looking to swap to a Vega nano (undervolted to around 180w) and a Ryzen 2600/2700. The lack of quiet flex PSUs is a pain.
Untero
83
80
2. HDPLEX 400w ACDC
3. Half Life 3
4. Star Citizen
Could that be due to some general manufacturing-related problems you hinted on stream?
TheHig
951
1,171
It will come out. Lot of people waiting for sure but if we can get a brickless S4M with 1070+ GPUs the wait will be worth it.
Interested in fitment and Josh’s results with the Vega Nano in particular. :thumb:
HYPERTiZ
87
I'll fall in love the moment I can power an light/decent OC on a 8700k cooling with a (case mod to fit the) scythe bs2 rev.b and the RX 570 ITX Pulse (downvolted most likely)
All in a brickless 400W Skyreach 4 Mini <3
Reactions: TheHig
