Motherboard GIGABYTE AB350N-Gaming WIFI
Nonononoki
Posted on reddit (https://www.reddit.com/r/sffpc/comments/6ifbl5/gigabyte_ab350n_gaming_wifi/):
*mumbles* I don't need it, I don't need it, I don't need it, I don't need it, I don't need it.. *mumbles*
I NEEEEEEEEEEEEEEEEEEEEEEEEEEED IT!!!
Since they've been mass produced, they will be available for purchase soon, right?
Pelican
66
65
Do we know how much it is expected to cost?
My opinion is swinging back to the Gigabyte board now. The ASRock one isn't going to have USB 3.1 apparently, and it also has less rear USB ports and no LEDs which is a downer. Optical sound isn't worth that to me, but I'm still annoyed Gigabyte left it out.
Nintenrax
It has an internal S/PDIF header though, so you could make it work somehow.
carbonitetoast
29
36
hey look a review: https://lanoc.org/review/motherboards/7570-gigabyte-ab350n-gaming-wifi
"So with an MSRP of $114.99, the AB350N Gaming WiFi is actually a good value and is priced close to the Gaming 3 with the extra cost of the WiFi bumping the price up $. I was told that there should be a small availability of the boards this week with more coming in later when the main shipments come in via sea."
TheHig
951
1,171
You make a good point concerning the layout. I have the Gigabyte z87 wifi and the layout is pretty similar too. Hasn't been an issue in a few chassis it's been in. Latest being my Son's Hadron air.
I know I have been all over the Asrock board but sooner may be better!
Jonny727272
275
218
The biggest problem I'm having is the front panel headers. I've had to buy an extension kit since the button on my case doesn't reach far enough as is.
TheHig
951
1,171
Yes. Those can be an issue with this layout. Keeping the cabling tidy too as mentioned by others.
Jonny727272
275
218
My biggest gripe is the location of the 8-pin. How am I am supposed to hide that cable without using a large Scythe HSF? However, with support for USB 3.1, I still prefer this board over the 3.0 limited ASrock board.
Not only that, but there being 3 less USB ports on the rear I/O of the ASrock board is a total deal breaker. I would instantly use all 5 up with peripherals.
3lfk1ng
919
1,718
www.reihengaming.com
I have an Anker USB hub since I often switch between desktop and laptop so that's non-issue for me.
But I have an external Samsung T3 SSD that is USB 3.1 so I don't want to miss out on that if it can be avoided.
Pelican
66
65
The mobo has also appeared on at least three New Zealand stores for around $220 NZD incl. GST (which is $161 USD if you convert that exact amount, but NZ prices are always more expensive). Out of stock on all, but some allowing for orders. I managed to secure an order on one site for $209 NZD but they've since increased the price.
cadiguno
128
116
Gigabyte's stuff is generally more expensive than it should be in Indonesia, I think NZ (and other SEA / OCE countries) are on the same boat.
But due to the amount of USB ports and WiFi I think I'm still going to get it even if it's overpriced.
Reactions: Pelican
7,732
$220NZ isn't bad really, as that's about what I paid for my Gigabyte F2A88XN-Wifi a couple years back.
Reactions: Pelican
