I believe so, as the rad clearance is going to 46mmWill the Alphacool ST30 240 V2 radiator fit in the case? And with 25+15 mm fans?
Dimensions are different and same with the vertical stand.I've been very happy with the T1 v1.1 I've been using for the past year. Hyped it up so much among my friends that one of them made the jump into SFFPC too and loves it. Congratulations on all your success with the T1 and in popularizing the SFFPC community. The v2.0 looks really interesting, but I'm afraid I'm too happy with your first product to make the switch.
Those aluminum side panels look killer though. Are they compatible with the v1.1 or have those dimensions changed?
Not in the plan b/c they are different sizes, which will take a lot of time to reset the machines.
Sorry, could you put it plainly for me. Is it possible to use a 280mm full custom loop with a 3080? I have a 3080 that's not fe but I have been looking at getting inlet/outlet ports that are rotating right angles or 45 degrees, so if the usual inlet/outlet direction was the limiting factor I should be good (my card will be solely the thickness of the card and waterblock).I have not used my side bracket to fill and run a loop, just the test fitting I did. I will make those available soon (life is too busy). The reason I decided not to pursue it is the top radiator would use most preheated air that has passed through the side radiator. All exhaust wouldn't really work for the part of the radiator next to PSU (and really this part is relying on the PSU fan anyway). All intake didn't seem like a good idea either, as there would basically be no exhaust fans to direct the air out , and might be a mess.
So based off the experience of a single 240 being overwhelmed by high end CPU and 3080/90, and a dual setup being marginally better with much more headache, it seems like a single 280mm with full size fans would be ideal, since that has nearly the same capacity as a 360mm. Just spitballing, moving from the T1s slim + standard fan on a 240mm radiator to a 280mm with 2 standard fans should yield a 50% increase (more rad surface area plus a standard fan replacing a slim). And then of course you have the simplicity of a single rad.
Of course the problem is this config ( 280mm loop) is only possible with 112mm GPU with side ports. If possible on taller cards, that would be awesome but of course PSU gets in the way of good airflow in sandwich... If only ...
This is the way
Honestly I think the answer is still....maybe - lol.Sorry, could you put it plainly for me. Is it possible to use a 280mm full custom loop with a 3080? I have a 3080 that's not fe but I have been looking at getting inlet/outlet ports that are rotating right angles or 45 degrees, so if the usual inlet/outlet direction was the limiting factor I should be good (my card will be solely the thickness of the card and waterblock).
Compatible with the hottest CPU on the market, power-hungry GPUs and 142mm heatsink coolers.T1-Reference with Noctua C14S on AMD 5950X runs nice with FE3080.
Oversizing your current loop is now possibleHWL 280GTS is a really tight fit in both T1-Reference and T1-Sandwich, recommended only for nutters.
Even more hungry GPU compatibility (in terms of thermals)5950X + FE3080 / FE3080TI is my next personal build. Targeting lighter weight, reliability and overall stability. To that end it's fine (<85C for my use).
Kick those Phanteks T30 right in the balls...I'm also waiting for my NF-A14 IndustrialPPC-3000 for some testing.
x2 Noctua NF-A12x25 no moreV2 can run *two 140 fans, in a <10L setup, especially with down draft cpu coolers, I suspect this makes a lot of difference.
Santa is coming to town...No ETA atm, just stock piling
Do you have a link to those new AIOs? Can't seem to find them.With the new EK AIOs releasing - will the 61,9 mm Pump hight be an issue with 3 Slot Sandwich Mode ?
EK-NUCLEUS AIO CR240 VISION D-RGB (link)Do you have a link to those new AIOs? Can't seem to find them.
I have a ventus 3x oc which current waterblocks look like they might be too thick for this, we'll see (after I buy it). Is the gpu space able to be a touch bigger with thinner fans? I think Prolimatech have thinner 140mm fans. In any case, this is 20mm thick so will fit in the space and can be used with any angle fitting you need.Honestly I think the answer is still....maybe - lol.
I'll spell out my thoughts on this as I plan my loop too:
In order to use a 280 rad with anything other than the a 30xx FE, the case will need to be in sandwich mode.
280 rad has to be on the side and for fans to fit along with it, the case will need to be setup with the smallest gpu compartment possible, which is 1.25 slots.
1.25 slots is ~25mm of gpu side clearance.
Most waterblocks are about 20mm in thickness which leaves you with about 5mm between the side of the waterblock and the mesh side panel on the GPU side.
This means that tubes coming from the GPU cannot run over top of the waterblock as there will not be room. This makes the rotating style terminals somewhat useless.
Because of that, the EK FE blocks where the tubes would come out of the end of the card and head toward the front of the case would be the easiest option - that said, I think the FE blocks might actually be too thick for 1.25 slots, coming in at 28.6mm thick.
Therefore, I think the best GPU option for this to work is the card with the shortest PCB possible (height from Pcie slot to top of card) with something like an EK angled terminal that sends both ports on an angle towards the front of the case. I'll be trying this with an XC3 3080 and the EK angled terminal in an effort to get a dual 240 loop going. I think the XC3 is one of the shortest height cards and would have the best change of having the fittings/tubes clear everything in this configuration.
Sorry for the word vomit but hopefully this helps to understand how the side mounted radiator situation would need to work...lol.
The 1.25 slot config leaves you with 48 or 49mm for a cpu pump block based on 15mm fans so I would say no to the first question. Unless you could fit a pump somewhere else in the system and use a typical CPU block without a pump.I have a ventus 3x oc which current waterblocks look like they might be too thick for this, we'll see (after I buy it). Is the gpu space able to be a touch bigger with thinner fans? I think Prolimatech have thinner 140mm fans. In any case, this is 20mm thick so will fit in the space and can be used with any angle fitting you need.
After rereading your response I have a question. Is a side mounted rad not on the same side as the gpu? You said 5mm between the waterblock and side panel, most cases I've seen with side mounted rads have it in front of the gpu.
Thanks for helping outEK-NUCLEUS AIO CR240 VISION D-RGB (link)
What about sandwich in 2 slot mode? EK and Corsair new 240 aios looks awesome, would be cool with the future tempered glass side.Yep, doubt that will fit. On v1.1 the clearance is 50mm in 3 slot mode. In v2.0 it's just a few mm wider, so not enough.
Well yes, that shouldn't be a problem. May also fit with the 2.5 slot mode, maybe.What about sandwich in 2 slot mode? EK and Corsair new 240 aios looks awesome, would be cool with the future tempered glass side.
Because not all of us want to lose our sanity installing a 280 in the Sandwich layout lmaowhy you are guys looking at 240 radiators? I would be trying to find all the 280 that can fit in v2.0
