    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
worldtour
56
133
Here's a little preview of my build. Just the GPU side for now.
I'm going to keep running benchmarks and tweaking fan settings but overall it's such a sigh of relief to have it near complete.
DrLeroy
Noob Saibot
May 15, 2020
186
117
So no one who has their case yet has tried the LT Solo on the X570 strix yet to save me the trouble when i can finally place an order for this case haha?
side note my TX240 rad shipped yesterday, so i should have all parts required waiting for the ability to actually get a case soon :)
SSJ4
131
210
www.ospreygaming.com.au
Got the 25mm-thick Coolworld 240 radiator w/ fill port in. Top (closest to camera) is Coolworld, bottom is LT240-
And for those that orient the radiator in the traditional layout (tubing ports underneath the PSU), the fill port does appear to line up very well with the hole in the back of the case if you mount the fan between the radiator and motherboard. I believe W360 has the radiator (or posted pics of it previously), so he might be able to verify it.
That is very interesting.
Would be pretty cool to plumb up to that thread for ease of filling/draining. Could you take a photo?
Reactions: DrHudacris
stanleyguan
114
331
  • Wow
gwertheim
938
1,555
DDC 1t plus PMW!
Thx I tried reading through thread again and finally found it about an hour after I posted that comment.
What is your second choice? It seems that ppcs doesn't ship to Canada right now and I can't find it anywhere else :(
fabio
1,885
4,325
Then, the second choice is the EKWB 3.25. But keep it at low speed, between 20 and 40 max!
bynio
70
74
I found out today on reddit that this case only supports the L12S on one direction. So if you use the case flipped then the CPU cooler will be bad positioned according to what noctua recommends.
I’ve been trying to find opinions about this but didn’t find much, so I’m asking just in case anyone knows if it is better having the case flipped despite this or having it defaultwith the good position of the L12S but the case fans on the bottom.
I'm using L12S on Aorus x570 wit pipes in horizontal position so it's the same with flipped as normal.
But right now I'm space limited so it's vertical and L12S is positiones 'incorectly'/pipes bending at the top and not seeing much temp difference, except that we're having hot summer, high ambient.
Reactions: carlosjtacon
gwertheim
938
1,555
What's the difference between 1T Plus and the 3.25? My guess is 1T Plus has lower RPM, thus lower power consumption and noise?
For reference, Alphacool puts up this picture on their product page:
It has the fabio stamp of approval of course. Companies have to jump through hoops, spend thousands on bribes and sabotage the competition.
