    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
0x3F2D
37
29
I remember this being posted before: https://www.aliexpress.com/item/1597148545.html
Just one question. Will the 24 V rating be an issue for PC use? Unsure if it needs 24 volts or can handle up to 24 volts... As far as I know a regular PC power switch uses 5 volts. Not an electrician so sorry if this is a stupid question ?
The switch can handle up to 24 volts and will handle the 5 volts just fine.
Reactions: Chaca
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
2020-07-02: T1 first shipping date delayed to 2020-07-24!
Preorder date will still be 2020-07-03 9AM PST, but the first shipping date is delayed to 2020-07-24 (this is NOT delivery date).
I made a late change to the material used for the feet on T1 and the supplier is late. However, the trade off is worth it. If you want to learn more about the change, watch this video.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
2020-07-02: No Email Notification for first drop - not enough inventory. Will Email after we get more inventory.
There are too few T1s for the 2020-07-03 drop (shipping 2020-07-24). So we don't want to email all subscribers just so they can get mad not being able to get one.
We will email subscirbers once we have a bigger batch coming in.
Ashenfall
57
79
The best kind of delay - when it leads to a better product. Great job!
immanoel
Not really that mad of the limited cases, eventually all of us probably would have one, maybe it'll even have shipping for other countries by that time.
Reactions: DrHudacris
conmanique
I will sit tight!
DrHudacris
918
1,720
@DrHudacris that stock cables look close to touch the 25mm fan! may I ask what is the actual clearance do you have there? do you think low profile connector / slim cables can give more clearance? Asking to see if there's 7mm to gain for my EK AIO 240 hahaha
I'm not sure the actual mm distance between PSU and first fan, but I can tell you I had to use a sort of grill to keep the cables from brushing against the fan blades. So it's very tight!
Reactions: thelaughingman
ManaNeko
43
49
My white desk thanks you for your consideration.
Can't say I like the feet of my DAN-A4 v1.
Reactions: kmnvhs
