With first flights to Poland being resumed I finally got to my T1 from test shipment. Yay!
Sorry for bad quality pics. And please don't laugh about HD 7770, I know and I will upgrade some day.
Standard hole alignment issue already reported. DisplayPort unusable because of it being too close to the edge in default build and HDMI barely giving signal. I will try to align it again and see if it helps.
Embarrassing issue with L12S. It doesn't fit with Aorus x570. I've used it in Ghost before and had to bend the pipes. It is lower then new but the structural bar in T1 still presses on it and bends it slightly in. I wouldn't recommend trying it with full 70mm. Rotating 90 degree may help (didn't try yet) but heat pipes would go beyond motherboard and potentially interfere with fan. It didn't fit in ghost at all when rotated. Also positioning L12S with heat pipes upside down is not recommended by Noctua, so that limits options.
There is L12S Ghost edition
NH-L12 Ghost S1 Edition
Noctua’s classic NH-L12 has proven to be the best air cooling solution for Louqe’s award-winning Ghost S1 enclosure. With its single NF-B9 PWM 92mm fan, the new Ghost S1 edition is tailored for use in this case and has been updated with the latest SecuFirm2™ mounting hardware for all current...
I hope, with this T1 Hype.. there will be AIO with good QC will produce for T1
