    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
Truth
Formerly TutorialIsland
Mar 19, 2020
90
46
Filled it out, sadly the same is for myself, March 19th is certainly not senior haha. But I understand the necessity of this given our current situation, I'm just hopeful I can get a shot at this in June so that my build goes smoothly.
cldskt
34
29
2020-04-15 Update: T1 Reserve Survey
Due to the supply limitation of the T1, we are considering a reserve for people that have followed the project for a long time. So this survey is for collecting information to help us identify seniority, which helps me determine how much inventory to hold for senior followers.
There are definitely a lot people who have been following this project longer than me, and I think they should get priority over me. But how do you propose people who have gotten the case through QQ Group from getting another one? Or is that just how it is? ?
JayRello
26
53
He has their user names from when they made an order.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
QQ group has V1, June gets V1.1
Reactions: NinoPecorino
Truth
Mar 19, 2020
90
46
I know you are generally against people trying to use anything aside from the LT240, but I genuinely have to ask if this is possible.
The LT 240 = 270 x 120 x 25mm
The NexXxoS ST30 (Optimum Tech's video) = 275 x 124 x 30mm
The EK-AIO 240 D-RGB = 275 x 120 x 28mm
Therefor, couldn't I theoretically fit the EK-AIO 240 D-RGB with thin fans?
Would want this setup so I could expand in future in a similar, but less gunk-chance way than the LT-240.
Thanks for any response, @Wahaha360
gwertheim
938
1,555
Check the specs in the first post then talk to @fabio if I'm not mistaken he's done a build without a lt240. @Wahaha360 has tested at least 5 or 10 rads with a couple of degrees difference.
To be fair to the lt240, you are replacing the liquid and the tubing for it to fit in the case properly. So there is less chance of gunk build up if you use rubber tubing. It's been discussed in great detail in this thread.
If i am not mistaken the max thickness you can go is 25 mm because the Noctua NF-A12X15 is 15mm thick which is the max amount of room you have to work with. Again @fabio or someone with the case will have a better idea
Reactions: Gerold
Madhawk1995
84
62
Posting for reserve list as well. Created this account 2 days after my birthday hoping I could get the t1 the same week back in September obviously that didn't happen and I went with a ghost and done a ton of mods. As of now direct die 9900k 5ghz 240 aio and running a stock air cooled gpu. Looking to shove a LT240 in t1 for cpu and arctic accellero 3 for gpu unless I can snipe a great deal on a 2080 ti strix. Still miss my strix 2080 after selling it for a evga 2080 2 slot for ghost.
Truth
Mar 19, 2020
90
46
Yeah no I get the point of the LT240 and was originally planning to do it, but with Optimum Tech's 3 videos he shows that we can fit more than the 25mm thickness, as his radiator is 30mm thick, which I noted in the question, therefor my 28mm 240 should fit just fine with the slim fans.
FischOderAal
73
77
Aaaaw. Shucks. I just recently got to know about this :) NCase M1 v1 SN112 reporting in :D Even though I am currently on a Dan Case A4. This case looks to me like the perfect mixture of both worlds. Thank you very much for your continued efforts!
gwertheim
938
1,555
Check out @fabio build log, he has detailed parts list and measurements.
Reactions: Gerold and fabio
FischOderAal
73
77
With the thread search I wasn't able to find the discussion. The point is that the tubes should be shorter to fit properly. And why replace the liquid?
