    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
Amathophobia
21
really tempted to buy this, but want to see some of the test shippers try a custom loop in the T1 before I start buying some water cooling parts. this is the same aio that Wahaha recommends in the first post right? And it’s possible to remove the tubes and change them out as well?
Yes this is only 240mm radiator that will fit and is worth a crap from Wahaha's testing. Yes you can remove the tubes, the radiator and pump have standard g1/4 threads.
Proflucifer
92
42
If I remember correctly. There was something about removing the quick disconnect in to make the stock tubing fit. How is this done?
chinyang
45
79
how is the 3.5 mounted? is it easy? i couldn't really see from pic
Actually it’s screwed in on one side only, I placed some pads to support the other side. Just to demo/show/try out that with a little bit of creativity, there’s no lack of storage options. Alternatively, that space should allow at least a couple or more 2.5 inch SSD
Reactions: oopsiesoup
Floris
29
73
广州市 is the name of the city Guangzhou.
离开 means 'departed' (from this context).
So, my guess is that the case has been moved from Dongguan (the city of warehouse storage) to Guangzhou and has subsequently left Guangzhou's handling centre.
I think, there is no update since 7th March as the package has already departed China (by plane from Guangzhou) and therefore you will have to track it within your country's system.
Mine was at this state for 5 days. Then it suddenly showed up at my local customs.
Van0
129
166
Interested in this as well. Still not sure if I want to go a full custom loop or LT240 with a Accelero Xtreme III, which would require removing the quick disconnect too I believe.
Reactions: forestpatrol
Floris
29
73
The alphacool LT uses standard fittings, so you can just unscrew them and replace the hose. You'll have to refill the loop though.
Reactions: SoSquidTaste
SSJ4
131
210
www.ospreygaming.com.au
Removing the quick disconnect is recommended by not required for 2slot mode. Just makes clearance and fitment alot easier. But it can be done.
He did say that it will have to be removed for 3 gpu slot mode.
Personally I am going to opt for LT120/240 on cpu in 3 slot mode so I can have a beefy air cooled gpu.
Seeing the 3.5" drive in your build has made me think of the possibilities. I can find a LT240 for a fair price but I can get a Kelvin T12. So I am thinking settle for 120mm now and run my 3tb hhd. I cant afford to replace all my storage right now so if i can use my drives i will.
When I get my case I think I'll look at designing custom brackets for storage.
Also have you seen that 3.5" enclosure that takes 4x m.2 drives? Crazy haha. I was thinking of putting that in in the future.
threestripevida
277
466
I'll just leave this here.
yeah, after watching that with the upgrade to make it all fit properly, I’m gonna get the T1 and try my hand at a custom loop.
It seems like the bulge on the top panel was also fixed? Did anyone else notice that? He didn’t mention anything about it in this video.
heckinwoofer
101
142
@Wahaha360 How wide is this gap supposed to be? Nominal and tolerance? I measured it to be very slightly under 120mm. There is positive interference; the AIO doesn't fit. The AIO I am using is Corsair H75 which is exactly 120mm wide. I saw @tyen use the H60 which is also 120mm wide and he can fit it in.
Update: Managed to force the rad in after sanding it down. We should't go through this much trouble for radiators with 120mm nominal width.
SSJ4
131
210
I wish he would have used the right rad and fan config. I imagine noise would have been better.
We are talking the difference of 1 15 vs 25mm fan. There may be a small measurable difference. But in practice with the rest of the system noise i doubt you could tell in daily use.
Besides. The sT30 is a thicker and denser rad. So you can run the fans slower for thr same temp. Cancellimg out the noise difference most likely.
That said. I also wish he used thr correct rad since it is what most people who go water will be using.
DrHudacris
918
1,720
Would it have been possible to mount the rad further aft to avoid colliding with those structures?
tyen
41
180
It is a quite tight fit. I had to squeeze it in gently.
I didn't have to sand it however.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
It should be 120mm.
Did you measure the radiators width?
Reactions: Amathophobia
