Honestly there are bunch of brands' logo worst than "DAN".Apple logo looks great. DAN is just a person's name.
I am comfortable with current design
Shame about the brand on the front panel that kinda ruin everything.
Well, the Ventus is a reference sized card... I dont see why you wouldnt be able to fit it?I got a question, specific to my build. Could I somehow fit this card inside of C4? Like with low profile power cable adaptors, etc.? What is the absolute maximum GPU height for C4?
Reference models are only 112 mm in height, mine is 128mm, so I thought It might be a little bit too tall for the classic layout (forgot to add this last bit on my original question).Well, the Ventus is a reference sized card... I dont see why you wouldnt be able to fit it?
Thank you for this info. I'll go with the C4 then. One more question: is there any chance you will offer C4 without a raiser cable for those of us that prefer the classic layout?It will fit![]()
UPDATE
Here is the feature list of the final sample of the C4-SFX
Added features:
1.) GPU top = default
2.) 16mm more in width (CPU heatsinks up to 145mm)
3.) 3mm more in height (support Noctua C14S on all boards)
4.) Full 140 Fan support for GPU intake or Ghetto Mod
5.) Remove Slot-Hole bars - it is now one single hole (improve temps for Blower and 30x0 FE cards)
6.) Include an optional GPU exhaust duct (hot air from 30x0 FE back fan will be not recycled by the AIO it will forced out over the sides)
7.) More vent holes on the side panel
8.) All sides can be covered (on the old sample the bottom would be open if GPU is on top)
9.) Improved AIO bracket (more airflow) and shift able to two positions.
10.) Increased stiffness of the chassis.
11.) Easy way to install even GPUs that uses the complete internal length without take the case apart.
12.) Optimized compatibility for SFX PSU mounted with exhaust to the front. This one will be the primary PSU position. It will support C14s with dual 140mm fan and also (Feature 6 on AIO mode)
13.) Iceman Pump-Res combo support.
14.) Improvement on the motherboard tray - the GPU can move more air out the case under the board.
15.) Two location for PSU power inlet. (Increase compatibility for some heatsinks)
16.) The GPU must no longer source through two layers of vent holes (ref. Optimum Tech Video)
17.) No GPU sacking bracket.
18.) Simplify cooling best practice
- GPU on top pulls air in and exhaust over left, right and back side. GPU will nearly not affect CPU cooling solutions)
- Tower Heatsink: Pull air from the back, exhaust over 140mm fan on the AIO bracket
- Top down Heatsink: Pull air from the bottom, exhaust over 2x140mm fan on the AIO bracket
- 280 AIO: Pull air from the bottom, exhaust over 2x140mm fan on the AIO bracket
Dropped features:
1.) Sandwich Layout
2.) PSU rotating 90°
3.) dropping 240AIO and 120mm Fan support on the AIO bracket
Evaluating:
1.) USB-C Port next to the Power Button (90% final)
2.) Special duct bars for Ghetto Mod so air will be forced into the GPU heatsink.
3.) Making outer panels with sand blast and die stamp
Hi @dondan, can you please elaborate on the PSU orientation as described? I’m trying to visualize how exhausting toward the front of the case works, and where the PSU intakes from in the GPU-on-top orientation.Added features:
