Do you think it'd be possible to do a push and pull config with 25mm and 15mm fans on it? It's a 38mm rad by itself, so I just want to be sure.
Remember that Arctic P14s are 27mm thick, not 25. There are also no particularly good slim 140mm fans on the market, so the benefit of adding any would be dubious at best. I would go with the stock fans for that AIO. They are great fans.Do you think it'd be possible to do a push and pull config with 25mm and 15mm fans on it? It's a 38mm rad by itself, so I just want to be sure.
Planned on using Noctua 25s with Nocuta 15s as wellRemember that Arctic P14s are 27mm thick, not 25. There are also no particularly good slim 140mm fans on the market, so the benefit of adding any would be dubious at best. I would go with the stock fans for that AIO. They are great fans.
The Arctic AIO you posted is 280 with 140mm fan. All 140mm Noctua fans are 25mm. Fans (noctua.at)Planned on using Noctua 25s with Nocuta 15s as well
Noctua currently has no 140mm fans that are competitive with Arctic P14s - their NF-A14 is a much older design than the NF-A12x25, and the A12x25 is barely better than the Arctic P12. The P12 and P14 are the same design in different sizes, so the P14 should then noticeably outperform the P12, unlike the NF-A12x25 and NF-A14. (Noctua themselves marketed the NF-A12x25 as performing the same as or better than their 140mm offerings ...). To me, it sounds like that fan swap would double your AIO's price for an increase in noise (as you're exchanging two fans for four, even if they're quiet that noise adds up) and at best performance parity, at worst a drop. And as @ten13th said, Noctua doesn't have any 140mmx15mm fans.Planned on using Noctua 25s with Nocuta 15s as well
Ended up finding a complete workaround. Gonna just use this.Noctua currently has no 140mm fans that are competitive with Arctic P14s - their NF-A14 is a much older design than the NF-A12x25, and the A12x25 is barely better than the Arctic P12. The P12 and P14 are the same design in different sizes, so the P14 should then noticeably outperform the P12, unlike the NF-A12x25 and NF-A14. (Noctua themselves marketed the NF-A12x25 as performing the same as or better than their 140mm offerings ...). To me, it sounds like that fan swap would double your AIO's price for an increase in noise (as you're exchanging two fans for four, even if they're quiet that noise adds up) and at best performance parity, at worst a drop. And as @ten13th said, Noctua doesn't have any 140mmx15mm fans.
I really like Noctua, and I'm really looking forward to seeing them bring the NF-A12x25 design to 140mm fans, but that's still a ways out.
Speaking as a previous Noctua diehard who recently swapped to a single 280mm rad with two Arctic P14s: buying an Arctic AIO and swapping out the fans would be an incredibly stupid thing to do.
Interesting, let us know your results! A 240mm rad has significantly less surface area than a 280mm rad (which is closer to a 360mm), but those fans are also really good. At least they've given it a thicker rad to give those fans something to work with. Definitely an interesting product!Ended up finding a complete workaround. Gonna just use this.
I was kinda disappointed to see that there was no 280, but I'm hoping they can come out with a 280 version soon with some 140mm 30mm fans as well. That would give Arctic a run for their money.Interesting, let us know your results! A 240mm rad has significantly less surface area than a 280mm rad (which is closer to a 360mm), but those fans are also really good. At least they've given it a thicker rad to give those fans something to work with. Definitely an interesting product!
those fans would work great in this case with a thicker than normal rad or a more dense one. Interesting!I was kinda disappointed to see that there was no 280, but I'm hoping they can come out with a 280 version soon with some 140mm 30mm fans as well. That would give Arctic a run for their money.
Apparently, these have been tested and are quieter than the tan and brown Noctua 120x25s, and perform significantly better as well, so I'll just have to see when I get your case in my hands.The main advantage of an 280 AIO vs 240AIO is not that much cooling it is noise.
Hard to say without the case nor the cooler!how will silver arrow 130 be different from one fan c14s in this case for air cooling?
I was wondering what might fit well for air cooling with the additional height besides the C14S with dual fans and then the Silver soul was released.The C14S can only outperform the SA130 with dual fans. Interesting is also the new Thermalright Silver Soul 135
There are some planned revisions that haven't made it to the front page.1. How many fans can you slap on a SA130 in this case?
2. And why do we consider silver soul 135 if the clearance is only 130?
3. And in the case of 120mm fan tower coolers will you slap a Noctua fan or a Phanteks T30?
4. When you say dual fans, do you mean dual a14 or one a14 and another a12x15 on the fan bracket, or is there a slim 140mm fan to try?
