DAN C4-SFX
dondan
DAN Cases
1,981
8,392
For the C14S you can install two 140 fans on the radiator bracket in a row above it. For Founders cards you will get massive air moved out the case.
What do youm mean with your last question?
Reactions: millerbedicks
fish.ch
32
31
I was asking the design choice to make the max gpu length 320mm instead of a few mm longer.
I guess it's first unspoken/de-facto "standard" length after official pci-e maximum of 312mm. Just like 10.5inch/267mm is not stated anywhere, yet there's a lot of cards just under/right at that length.
dondan
DAN Cases
1,981
8,392
After I got the new sample of the C4-SFX with a max cooler height of 145mm I will test some air coolers that will now fit:
Be Quiet! Dark Rock TF 2 (https://www.bequiet.com/de/cpucooler/3351) - 725g heatsink only
Noctua C14S + dual 140mm (https://noctua.at/de/nh-c14s) - ~850g heatsink only
Thermalright True Spirit 120 M BW Rev. B (http://thermalright.com/product/true-spirit-120-rev-b/) - 450g heatsink only
Thermalright Silver Soul 135 (http://www.thermalright.com/product/silver-soul-135/) - 580g heatsink only
Cryorig H7 Quad Lumi (http://www.cryorig.com/h7ql.php) - 585g heatsink only
Stinkybear
98
91
After I got the new sample of the C4-SFX with a max cooler height of 165mm I will test some air coolers that will now fit:
Yes. Very interested in Noctua C14s and Silver Soul 135 and comparisons in general.
millerbedicks
Should c14s be better than the silver soul 135, because of more heatpipes, heavier heatsink, and bigger fan?
And how do you even buy a silver soul 135 to begin with? I can not find a site that sells one in Canada.
schneeland
Maybe not the most pressing thing for most people, but are you planning to offer a fully black version at some point after the silver one is out?
schneeland
Excellent! Thanks a lot!
Another design-related thing: does the logo on the front double as power indicator (i.e. is there an LED behind it)?
