DAN C4-SFX
Schnaxelhuber
Update:
After the release of the new RTX 3x00 FE cards I consider to not make the fliped layout (GPU on top) the default layout. It will be still possible to flip the case to get this orientation. As my test shown the best configuration for overall temps is the side mounted radiator pushing air outside the case. With the GPU on top the radiator will source fresh air over the bottom. This is already not optimal because this intace is limited by the case feet height. New founders cards will also push hot air into the radiator zone. This will made the situation more worse. If the GPU is on bottom the radiator will have more access to much more fresh air through the top panel. Maybe I am worng but I will test it with a RTX 3080 FE.
Btw: For me the new RTX cards are a big step forward and it is something like the 8800 GTX in the past.
I honestly don’t get why the new gpu cooler design should be a problem for the cpu temperatures. It’s not like the new design is creating heat energy. If anything the new design is creating less Hotspots at the sidewalls and pcb.
so I see it as a much more efficient gpu cooling at the expense of slightly worse cpu temps. but I would still prioritize better air access at the top of the case for the gpu in flipped mode. Especially with a water cooled cpu you will always be more concerned about the air cooled gpu.
i think for the system as a whole the new fe cooler design is a big win.
Notional
48
54
Indeed. Whether the backplate/pcb of the graphics card or a PSU up against the card is stopping airflow, really doesn't make any difference. But I also don't think the coolers are the problem, but rather the insane tdp of these cards. 320-350w/tdp + overclocking is not gonna fly. With a case like C4 it might make more sense to use a 240 CLC on the GPU and an aircooler on the CPU instead. Onderclocking/volting can only do so much after all.
teajanky
I actually think 280 rads would work wonders now. I would go rad > gpu > cpu. It's still a lot of watts for just one rad tho, and with next gen consoles having a zen based 8 core cpu, it might not be the same negligible power requirements for the cpu like we're used to. At least for games a few years from now, if the whole system is maxed out with blender or something similar it will probably just throttle at some point.
dondan
DAN Cases
1,981
8,392
Sorry if this has been asked before, but is the 300mm max GPU length the absolute max? Seeing the MSI 3080 Ventus 3x is 305mm. Other cards are even longer o_O
These values are based on the current prototype. I am in the process of changing the sizes tu support 280 AIO this will result in case with a increased length so GPU support will be upt to 320mm.
New case size will be something like this:
width: 151mm (+3mm to support gpus with a height of up to 130mm and more water blocks)
length: 333mm (+ 18mm to support 280mm rad in the GPU zone or side mounted zone)
height: 238mm (+6mm to support triple slot GPU in the bottom or 30mm height radiator + 25mm fans in this zone for sandwich)
Volume: ~11.9L
dondan
DAN Cases
1,981
8,392
Updated GPU and Radiator spec. for C4-SFX final design:
Side mounted radiator:
  • perfect fit: 280 rad - 315x143x30mm (LWH) + 2* 140x140x25 fans
  • max fit: 280 rad - 320x143x38mm (LWH) + 2* 140x140x25 fans
Note: With a set of slim fans like the upcomming Noctua A14x15 the radiator height could be increased up to 48mm
Bottom/Top mounted radiator (dep. on orientation):
  • max fit: 280 rad - 320x143x30mm (LWH) + 2* 140x140x25 fans
Note: For 280er radiator you have to use fans with round housing that fit between Lian Li clips like Noctua A14R. Raditor must sit on fans.
Extra Notes: I do not know a 240 radiator or 240 AIO that will not fit.
GPU support for both layouts:
  • Width: Triple slot ( up to 65mm )
  • Length: 320mm length
  • Classic height: up to 131mm (power socket has to be 18mm lower or 10mm if you use low profile 180° power turn)
  • Sandwich height: up to 165mm (power socket has to be 18mm lower or 10mm if you use low profile 180° power turn)
Note: RTX 3090 FE will only fit in sandwich layout
bushonpen
38
I am so happy that Liquid Freezer II 280 AIO will fit even if it is in the "max fit" category. It has the best performance according to GN and even if the VRM fan is practically useless in a normal size case, I think it will do some work in an ITX system. I can't wait for more information and even though I will upgrade my system when ddr5 comes out Q42021/Q12022, I will buy the C4 as soon as it is available to make sure I can get my hands on it.
Reactions: Ghillie
thelaughingman
1,413
1,566
@fabio will you do a dual 280 rad in the C4 pls ? ? ?
Demthios
Roughly how much clearance will there be between the back of the GPU and the PSU? Wondering how well the FEs will work in the sandwich layout.
Aleksander
41
32
Sounds like a great case! And one of very few small cases that can fit the new gen GPUs.
When can I buy it??
fish.ch
32
31
When can I buy it?
Dan is probably not going to give ETA or anything, but realistically speaking not this year. Don't get high hopes for at least first half of next year either. That's assuming Dan would be happy with prototype of current ('final') design and everything else goes smoothly.
Reactions: Navic
dondan
DAN Cases
1,981
8,392
RTX 3080 compatibility list:
here is the Nvidia RTX 3080 compatibility list. Some cards may fit (!) if you use a low profile 180° power socket adapter.
Furthermore some cards that are too long may be also fit if they are deshrouded, because the heatsink and pcb may shorter than the fan shroud.
CardSandwichClassic
ASUS ROG Strix GeForce RTX 3080not fit (length)not fit (length, height)
ASUS ROG Strix GeForce RTX 3080 OCnot fit (length)not fit (length, height)
ASUS TUF Gaming GeForce RTX 3080fitnot fit (power socket)!
ASUS TUF Gaming GeForce RTX 3080 OCfitnot fit (power socket)!
EVGA GeForce RTX 3080 FTW3 Gamingfitnot fit (height)
EVGA GeForce RTX 3080 FTW3 Ultra Gamingfitnot fit (height)
EVGA GeForce RTX 3080 XC3 Black Gamingfitfit
EVGA GeForce RTX 3080 XC3 Gamingfitfit
EVGA GeForce RTX 3080 XC3 Ultra Gamingfitfit
Gainward GeForce RTX 3080 Phoenixfitfit
Gainward GeForce RTX 3080 Phoenix GSfitfit
Gigabyte Aorus GeForce RTX 3080 Masterfitnot fit (power socket)!
Gigabyte Aorus GeForce RTX 3080 Xtremefitnot fit (power socket)!
Gigabyte GeForce RTX 3080 Eagle OCfitfit
Gigabyte GeForce RTX 3080 Gaming OCfitfit
INNO3D GeForce RTX 3080 iCHILL X3fitpower socket height!
INNO3D GeForce RTX 3080 iCHILL X4fitpower socket height!
INNO3D GeForce RTX 3080 Twin X2 OCfitfit
MSI GeForce RTX 3080 Gaming Trionot fit (length)not fit (length, height)
MSI GeForce RTX 3080 Gaming X Trionot fit (length)not fit (length, height)
MSI GeForce RTX 3080 Ventus 3Xfitpower socket height!
NVIDIA GeForce RTX 3080 Founders Editionfitfit
Palit GeForce RTX 3080 GamingProfitfit
Palit GeForce RTX 3080 GamingPro OCfitfit
PNY GeForce RTX 3080 OC XLR8 Gamingfitfit
PNY GeForce RTX 3080 OC XLR8 Gaming Epic-Xfitfit
Zotac Gaming GeForce RTX 3080 Trinityfitfit
iwe
31
21
Any thought if you are going to do redesign of the case based on the new GPU?
Leith
Since you are German as well (as I think, could be totally wrong o_O), will the availability still be prioritized in th US first ?
jaeparku
230
116
we don't even have an estimated target date range yet..no point in asking for which country will be prioritized yet ?
