The more options, the better, we shouldn't settle for just one thing.
Ah, yes, yes. The more options the better! Especially as long as they are Ncase M1 clones that look slightly different and support 280mm AOI. Very nice.
By your logic, all sandwich style cases are the same, or all standard layout cases are the same, and we don't need them. We just need the originals.Ah, yes, yes. The more options the better! Especially as long as they are Ncase M1 clones that look slightly different and support 280mm AOI. Very nice.
There is not. Just check back here every once in a while to get the latest updateswelcome to dumb questions with me
is their a email list to get on for release? wanna make sure I get this before it sells out when released...
@dondan If the case is made wider to allow for an bottom mounted 280 AIO, would this mean that it is enough space to deshroud an 2,7 slot gpu like Asus Dual (58mm thick) in vertical position?
That was a very informative video and really explains why so many A4 users complain about pump noise and poor performance.Turns out bottom mounted radiator not the best solution:
So maybe flip the case, so the gpu is on top and mount the radiator in parallel to the motherboard, but I am not sure if that fixes the issues mentioned in the video.
I'm actually a bit sad with the situation we have here. At the moment, we have 65-165 W TDP CPUs, and 300mm 3 slots GPUs. But 5-6 years forward, will 100-200W TDP CPUs become the new mainstream, and 4-5 slots GPUs become the new normal? And will we still be SFF?
I don't think that there will be any changes within 5 or 6 years in this regard and when there will be, it'll likely be towards the other direction. CPU's will be more power efficient and gpu's will shrink with them.
Unless you're doing some serious heavy rendering, a maximum of 8 cores is enough for the 95% of us.
I thought so too, but looking at the past few node shrinks & what we have now, I think we're not on exactly on the "efficient/cool/shrink" path. Efficient and cool technically yes, but not enough to shrink.
Well I am still using my 7 years old 4c/4t Haswell for 1080p gaming & development works. It works perfectly well, so yeah![]()
Even 4c/8t cpus are useless nowadays for moderate demanding work. A good old i7 is a decent cpu but still cores will never be enough.That depends on the games and your work flow tho. I wouldn't want to play assassins creed odyssey like that. It's hard to miss what you don't know but it's also hard to go back to 1080p 60 from my 1440p 144hz setup, at least for me. Anyway great it works for you!
The current version of this case is still flipable, so you can have the radiator at the top like in the picture you provided.Which is exactly why the old design upside down with the GPU at the bottom and on the left side of the case was the perfect version for me (the right one in black of course)
You can, but the GPU will now be on the right side of the case and hanging from the PCIe slot. I always have my PC on my right side and I like tempered glass sides, which would be pointless with the new design.The current version of this case is still flipable, so you can have the radiator at the top like in the picture you provided.
