D
Deleted member 19228
Guest
About the material, I think 6mm thick Aluminum could be a better choice if the price would not go up so high. It would make this case to be more premium.
Lian-li as the OEM so 2mm panels as listed in the specAbout the material, I think 6mm thick Aluminum could be a better choice if the price would not go up so high. It would make this case to be more premium.
Ty for the information, I hope there would be concept out there which has premium finish with the god-tier optimization like the Dan case C4 or the Ncase M1.Lian-li as the OEM so 2mm panels as listed in the spec
Good thing they called it a "Turbo Edition" because that thing is going to sound like a turbo jet engine if it has any hopes at cooling that card![]()
Gigabyte releases a blower and dual-slot NVIDIA GeForce RTX 3090 with a 350 W TDP
Gigabyte has released a blow and dual-slot version of the NVIDIA GeForce RTX 3090. The GeForce RTX 3090 TURBO 24G also has a 350 W TDP, to add to the fun of owning a blower RTX 3090.www.notebookcheck.net
Gonna be toasty
Seems like the Video cards are getting bigger and the standard is 3 slots and > 300mm. It maybe quite late to ask this question,but here we go! will you consider making some changes to this case or release a new one that will accommodate the upcoming new generations 3 slots and > 300mm length?
RTX 3080 compatibility list:
here is the Nvidia RTX 3080 compatibility list. Some cards may fit (!) if you use a low profile 180° power socket adapter.
Furthermore some cards that are too long may be also fit if they are deshrouded, because the heatsink and pcb may shorter than the fan shroud.
Card Sandwich Classic ASUS ROG Strix GeForce RTX 3080 not fit (length) not fit (length, height) ASUS ROG Strix GeForce RTX 3080 OC not fit (length) not fit (length, height) ASUS TUF Gaming GeForce RTX 3080 fit not fit (power socket)! ASUS TUF Gaming GeForce RTX 3080 OC fit not fit (power socket)! EVGA GeForce RTX 3080 FTW3 Gaming fit not fit (height) EVGA GeForce RTX 3080 FTW3 Ultra Gaming fit not fit (height) EVGA GeForce RTX 3080 XC3 Black Gaming fit fit EVGA GeForce RTX 3080 XC3 Gaming fit fit EVGA GeForce RTX 3080 XC3 Ultra Gaming fit fit Gainward GeForce RTX 3080 Phoenix fit fit Gainward GeForce RTX 3080 Phoenix GS fit fit Gigabyte Aorus GeForce RTX 3080 Master fit not fit (power socket)! Gigabyte Aorus GeForce RTX 3080 Xtreme fit not fit (power socket)! Gigabyte GeForce RTX 3080 Eagle OC fit fit Gigabyte GeForce RTX 3080 Gaming OC fit fit INNO3D GeForce RTX 3080 iCHILL X3 fit power socket height! INNO3D GeForce RTX 3080 iCHILL X4 fit power socket height! INNO3D GeForce RTX 3080 Twin X2 OC fit fit MSI GeForce RTX 3080 Gaming Trio not fit (length) not fit (length, height) MSI GeForce RTX 3080 Gaming X Trio not fit (length) not fit (length, height) MSI GeForce RTX 3080 Ventus 3X fit power socket height! NVIDIA GeForce RTX 3080 Founders Edition fit fit Palit GeForce RTX 3080 GamingPro fit fit Palit GeForce RTX 3080 GamingPro OC fit fit PNY GeForce RTX 3080 OC XLR8 Gaming fit fit PNY GeForce RTX 3080 OC XLR8 Gaming Epic-X fit fit Zotac Gaming GeForce RTX 3080 Trinity fit fit
Hi Daniel,
i really appreciate your work and I’m looking forward to get your case ?.
One question are your considering to provide in- and outlets holes in the back to add compatibility for the IceMancooler DDC? Would make custom waterloop before starting drilling the missing holes.
many thanks in advance.
Hi Daniel,Is there a more detailed datasheet or CAD to get dimensions?
