@sdbruder: Yes 3 Slot would be possible in both positions.
@Bonusround: There are still some tiny differences between both layouts. The sandwich layout would support GPUs with an increased height (PCIe Socket to Power Socket), whereas the classic layout will have no problems with up to 45mm thick radiators with 25mm thick fans.
@thelaughingman: You are right! In SFF every millimeter count, but if you check out 6mm on your ruler you will agree that this could be worth for getting these features. Also, on air cooling you will have more options like:
GPU indirect cooling (Case fan, GPU heatsink, default GPU fan removed)
GPU air feeding (Case fan, GPU fan, GPU heatsink)
- 2 Slot with 35mm thick case 120-fan
- 2.5 Slot with 25mm thick case 120-fan (Arctic Accelero)
- 3 Slot with 17mm thick case 120-fan
- 2 Slot cards with 25mm thick case 120-fan
- 2.5 Slot cards with 15mm thick case 120-fan
