Push/Pull.@Wahaha360 What purpose does that have in the c4? I'm not versed in custom watercooling but there is 55mm clearance iirc, so what's the point of going so thin?
Congratulations Dan, welcome to fatherhood. It will be hard and full of long nights but it deserves every effort. Waiting your news about the case. We can wait, enjoy your family.Yes it got it back a brand new tian X (pascal).My daughter Mia was born yesterday so currently I am very busy but i have very grat news for you I will stay with side I/O and found a way to make this case bettern than it is!
Well, with a normal sized rad Push/Pull is superior configuration vs Push or Pull. Check the video below for stats etc.@Metroversal I thought push/pull was almost the same as push or pull, and thats with the same size rad. sacrificing rad size would probably be detrimental to the cooling.
Yeah i mean 55mm gives you 30mm rad + 25mm (normal) fans. In my head especially with noctuas a12x25 fans this would be superior to a 20mm AIO+ 2x 15 mm fans in push pull. But this needs to be tested I guessWell, with a normal sized rad Push/Pull is superior configuration vs Push or Pull. Check the video below for stats etc.
I totally agree that surface area is important so in this case (no pun intended) it needs to be tested I guess. My only concern is that 15mm fans don't have a lot of static pressure.
Anyhow it's still cool to have Push/Pull as a viable option on a 10L case.
while some videos claim it is superior, others claim it is not. as far as I can tell - it's a myth. Better invest in bigger rads instead of smaller rads with double the Fans - if the Fans got enough static pressure to push the air through, another set of the same Fans running on the same Speed won't help at all. If they don't, it would help, but it would also help to just get the right fans for the job.Well, with a normal sized rad Push/Pull is superior configuration vs Push or Pull.
I want one
I don't think fussing about with push pull or thicker/thinner rads is gonna do much for the temps to be worth the headache and delay. This project is already gonna be delayed enough as it is. With the next generation hardware being around the corner, I'd rather have this case a few weeks sooner rather than later.
Sure if this stuff fits in the current design then you all are welcome to test it once it's out. Just please don't make Daniel change the design an do more testing to make these fit. Thank you very much.
Pretty sure he got those haribos at caseking.de; got some when I bought my keyboard there some years ago...@mb67 Wow where did you buy that Haribo? I want some radiators as a bonus gift too
Now to find a 2080 that will fit. The reference design 2070 will be unusable in this case due to the power connectors being on the side of the card. I am very excited for my upcoming build with this case. I will be using a 2080 with the 9600k.
Wow I knew that it looked small in the screenshots they posted. Didn't really is was that small pretty crazy they are packing that much power in it.The 2070 is only 9" (228mm) long, you can fit a 306mm GPU in the Dan, I think nearly 80mm will be enough to route your PCI power connector.
I'm eager to see some real world testing of the new NVIDIA RTX cards. With them now moving to an open air cooler, the ability of the chassis to exhaust the GPU heat becomes a much bigger deal than it has in the past, with the blower type coolers.
The upside is that if the C4-SFX is up to the task, we should end up with a much quieter system.
