Does anyone know the thickness of the heatsink/pump (the part that cools the CPU) of those AIO liquid cooling kits?
I made a Sketchup model of the 545LC if you want to check the dimensions. The block measures 27.5mm tall, not including fittings.Does anyone know the thickness of the heatsink/pump (the part that cools the CPU) of those AIO liquid cooling kits?
I have the 2080 FE, and you can pick toasty vs loud.Hey Guys, i want to show you my actual Dan A4 Build with an 30mm Radiator.
Ryzen 5 2600X (4Ghz@1,2V)
https://1drv.ms/u/s!AkV88dL5W2wUhJx7brS2EfUt7r9hvQ
https://1drv.ms/u/s!AkV88dL5W2wUhJx4sMl_QNvIbVTPyg
(One Drive Link, i will change these soon to imgur or anything else)
I also have a question for some RTX 2080 users.
Im interested in the Founders Edition or the EVGA XC, both Dual Slot. Noise is very important for me and my Gainward GHX 1080 GS is (with an 0,95V undervolting and a manual Fan Curve) very quiet. Almost Silent.
I dont expect the same cooling performance but it should be at least as quiet as a Noctua Fan arround 900-1300 RPM (PS4 PRO under „semi load“). Is this possible?
You mean, using either the 200W mini for the CPU and the 400W for the GPU or ONLY the HDplex 400W?Did you test it with the HDPlex that is able to handle 400W?
BTW, The system with the Titan RTX goes down at 440W, measured on the wall plug...You mean, using either the 200W mini for the CPU and the 400W for the GPU or ONLY the HDplex 400W?
I can try later, but I was trying to achieve this 560W in total using the Dynamo Combo, But Maybe I am missing something...
Thanks man!Awesome build maybe currently the most powerful. Do you power the gpu only by the kmpkt?
Thanks man!
Only by the 360 KMPKT. The 200W mini KMPKT is dedicated to the CPU and motherboard. Do you know how to to "merge" the two wattage of the KMPKT to have a total of 560W to be used for the entire system?
Build is fire yo.Voila!!
@Kmpkt , do you think I need the SYNC cable on? Every time I run 3DMark TimeSpy the computer shutdown like there's not enough power...
EDIT: with a 2070 it works with no problem actually so seems under load the Titan RTX use more than 350W, OR, I need to use two separate PCIe cable instead one of 20AWG with 2 connectors?
But the 360W is dedicated only to the GPU and 1 SATA SSD, and the 200W mini to the 9900K and motherboard...
The Brick is a Gury one, rated for 600W and more.
Anyway, enjoy!!
All Black DC Gentle Typhoon on a Black Ice Nemesis LS120 30mm Radiator
And the Queen!
Voila!!
Anyway, enjoy!!
And the Queen!
Yep! I’ve asked him one at 19V!And you are using a GUnique brick to power this? I might be wrong, but I thought he only made 12v bricks, KMPKT stuff runs on 19v no?
