DAN A4-SFX v4.1
fabio
1,885
4,325
Keep in mind the 2700X is 15°C lower in temps than displayed. AMD use this temp offset to have the fans more aggressive to reach higher clocks if the temps are good. The default 2700 has a higher temp limit and no offset. So in you usecase if you would have a 2700 none X and clock it to the same clock the temps would be 15°C lower without throttle ;)
I didn’t know that!
But about the temp, are you sure? I am pretty sure that the wrong reading temp has a delta of only 5 degrees and not 15...
fabio
1,885
4,325
@Tazpr How's that blackridge doing? what cpu and what are the temps etc? :) lettuce know lettuce know lol.
Anyway someone received an email that his/hers ADT DAN V4 Riser cable is shipped yet? I haven't got an email yet..
EDIT, no, actually I haven’r Received it. Only for the Dynamo mini ordered together... :(
JAugust
53
Ohh.. @dondan when will the risers be shipped? :eek:
and 85c on prime95 on the 2700X? I would say that's good though.. I wonder what the 3700 or even the 3700X would do under the stock blackridge.. and also @fabio - VAULT-TEC#6673 is my discord, you can talk dutch there too if you want lol.
fabio
1,885
4,325
Anyway, @JAugust just received the email of the riser shipment!
Reactions: JAugust
fabio
1,885
4,325
Hey @dondan and @hdplex , I have one question:
I am trying to mount the HDplex 400 in the Dan Case v3, but the PSU is going above the back of the power button. Am I missing something?
It was supposed from my side to remove the back heatsink from the HDplex?
Thanks to both!
EDIT: going through the HardForum I've found few pictures! Then I've used the standoff included.
Here a snapshot!!
fabio
1,885
4,325
Or maybe the HDplex DC can fit below the gpu and the brick vertical
Near by the GPU? Don’t know!
Creep
91
83
After I get my new RAM in, I'm going to finally lock up this A4 and take some pictures. Note to self: Don't let dust turn to cake or disassembling is in your future.
Can anyone suggest places where I can get custom extension cables aside from CableMod and overseas? Frozen CPU's office is literally 10 minutes from where I live but there prices are very high. Thinking of contacting the previous guy I had work on my S4 for some. I've been recommended lengths of:
24pin: 150mm
4x4pin: 250mm
6+2pin: 300mm
DarkCanuck
60
28
Thanks to both!
Here a snapshot!!
Beautiful!
Reactions: Alucard
