Anthony
79
36
I’m eager to see your final setup...:)
Oh yes, it's going to be glorious lol. There'll be a slide get delay due to funding problems for the components though. Sub frame failed on my vehicle 2 weeks ago; had to buy a new car. Wallet is a little tight unfortunately
MarcParis
Apr 1, 2016
3,836
2,998
Enthusiast issue..:) take your time..:)
jsco
60
55
Sorry for the posible repeated question. Max height?
"CPU Air Coolers
SFX Internal Kit: 137mm with the side hinge bracket installed, 145mm with side hinge bracket removed
SFX Rear Plate: 75mm max height
ATX Rear Plate: 48mm max height"
http://www.sliger.com/products/cases/cerberus/#specifications
(i think this is a little bit conservative, because the noctua nh-c14s fits with the side bracket in place, and noctua lists it as 142mm tall with the fan on top: https://noctua.at/en/products/cpu-cooler-retail/tdpguide)
MarcParis
Apr 1, 2016
3,836
2,998
"CPU Air Coolers
H7 quad lumi, without hinge, is the maximum cpu cooler height, ie 145mm tall.
Luminair
I think it has been covered elsewhere, but I just went through 200 pages tonight and I'm not remembering right:
What sizing is right for DEMCiflex dust covers for bottom and front on the standard Cerberus? I don't think they have something off the shelf, so I'm fine with customs. Just wanted to check first.
Johnny0971
24
37
I got a Cerberus X, and I'm using Ncase bottom filter for bottom intake, and I'm using 2x normal 120mm filters that they have for front fans, and for the side vent I use Ncase top filter.
It fits really good, I can recommend them.
rcradiator
117
79
Finally finished my build in the Cerberus X! Certainly not the easiest to build in, but totally worth it.
Pics:
Parts Link: https://pcpartpicker.com/user/rcradiator/saved/jZND8d
Johnny0971
24
37
Guys does anyone know if it is possible to fit a E-ATX motherboard and a SFX PSU in the front of the Cerberus X at the same time, or am I restricted to using ATX size board due to SFX PSU blocking?
Thanks!
MarcParis
Apr 1, 2016
3,836
2,998
Thanks!
In case of eatx mb, you have to go on rear mounted psu. Not enough space for front sfx psu with eatx mb.
Ubermarshall
110
44
Damn. Board has space for one m.2. Having said that, it is a 40 lane chip so i will have the (expensive) option of an x8 duel nvme card.
Original plan was going to ryzen atx.
The 1800x is in an itx (massive itx case for now), and on 4ghz on air.
I have since procured a nice 5960x sample, and an asus r5e 10 edition.
Reactions: MarcParis
Manic1
New member planing on getting the Cerberus X. Just wondering if all the parts I have and am buying will fit in the case.
Have:
nzxt kraken x62 2800mm AIO
Asus 1080ti strix
2.5 inch drive
3.5 inch drive.
4x8gb ram
will buy
ATX motherboard
ATX PSU
Case fans
May switch to a MATX motherboard and SFX PSU to save space.
What do you guys think?
MarcParis
Apr 1, 2016
3,836
2,998
Have:
Asus 1080ti strix
2.5 inch drive
3.5 inch drive.
4x8gb ram
will buy
ATX motherboard
ATX PSU
Case fans
Whatever case size, choose SFX-L psu (600W mini).
I guess everything fits in micro atx model, with front mounted psu. However you will need to replace side exhaust fan by 3.5 hdd...that I won't do with an open air GPU like your GTX 1080ti strix.
Manic1
What if I get the Cerberus x and put in a MATX board. Maybe mount the 3.5 inch drive above the rad with a custom mount?
MarcParis
Apr 1, 2016
3,836
2,998
you cannot put a micro ATX MB in Cerberus-X (by default) as Cerberus-X will have ATX standoffs that are not compatible with micro atx. You will need to tweak cerberus-X.
Taswegian
89
76
M.2 ssds only..:)
With SFX-L on rear and rad + fans on front there will still be plenty of room between those two to mount a pair of SSD on the hinged side bracket.
Another approach might be to order the handle kit and use it's support bracket to mount stuff to under the top panel but I haven't really thought that through so not sure how that would work out.
