Production cases: SLM1m/ SLM1 4L/ SLM2 5.7L by Custom_MOD
NoSk0pz
84
74
Batch 2 cant get here soon enough! :D
Curious what everyone's going to build with and what kind of temps people will get
Ceros_X
748
660
The Zalman CNPS2X should fit just fine with 27mm. I would not drop support for the noctua l9i, I feel that is a mistake on your part boss man.
Reactions: paullusty
mahdiy
It keeps getting bigger! why?
I used to have a wesena case like this one https://ru.aliexpress.com/item/HTPC...32657031565.html?spm=2114.41010308.4.6.7p2H4y
the space was enough solely for the motherboard, though the height was excessive. Are you making it taller now? where is the extra 0.3 liters from? edit: I see it's the height.
shave off some space on the width :-D
also what app do you use to design your projects? Thanks man. Still accepting an order for your slim or is cutoff point reached?
sergiiua
CustomMOD
Jan 11, 2017
1,146
2,047
www.custom-mod.com
A small increase will allow you to set a noctua L9i. I'll also add a mount for ssd 2.5" (thin 5mm)
