I was playing around with the cablemod cable configurator and noticed that, for the 24pin atx cable, the minimum length is 25cm (for other cables its 15cm). The SFF site article on this (https://smallformfactor.net/news/cablemod-configurator-design-custom-psu-cables) suggested that it had been reduced from 30cm to 15cm but this does not appear to be the case for the 24pin atx.
25cm is too quit a bit too long for an ITX case so perhaps i'll write to them and see if it can be reduced further. i can see no reason why it shouldn't have the same minimum as for the other types of cables.
