Production AM4 Brackets for CPU Coolers (C7 + others)
Thehack
Mar 6, 2016
2,813
3,676
J-hackcompany.com
W
Would it be compatible with the new c7g? Not sure if they use the same mounting solutions. I have one on pre-order and would like to get one of these, if it will work together.
It should, reported mounting dimensions were the same for Cu and I would imagine the C7G would be the same. I will supply a 3d printed washer/plate that should make it compatible. The stock one is a bit too thick.
Slowjim
53
25
Any way you could make me a set of brackets to rotate my Zalman CNPS8900 90 degrees? @wesbl has already made a prototype set. I could send you my Zalman and maybe he could provide the measurements?
wesbl
174
116
Italy
You only need AM4 Socket holes distances and Zalman brackets holes, thank you can make what you prefer for the design.
Be careful with Brackets material, you are near the cpu and PLA melts very easily...
Thehack
Mar 6, 2016
2,813
3,676
J-hackcompany.com
It wouldn't be hard to.
You can PM me but I'll have to see how difficult the mounting mechanism is.
WinterCharm
428
1,941
SE United States
W
No reason it shouldn’t be - the C7g is just graphene coated. Ultimately it’s the same thing, with the same mounting system and same brackets and compatibility
chrimen
52
NJ
I just fulfilled all the orders for the bracket.
I'll wait for some feedback before increasing stock level. Let me know if you have any fitment problems or any issues to report.
I just pre-ordered the c7 from overclokers and was wondering if you had any of these available or plan on making them again?
WinterCharm
428
1,941
SE United States
Just FYI I ordered a C7G from OCUK about a month ago and they have yet to ship it :p
Also, @Thehack I got my brackets, and backplate. They look good so far. I'll update once I get my C7G and actually mount it, but thanks again for being so quick about shipping this out, and for the communication and good craftsmanship :) I really appreciate it.
was pretty nervous because I'm new to the SFF Forums, and it's my first time buying from someone in this community. 10/10 dude.
chrimen
52
NJ
Also, @Thehack I got my brackets, and backplate. They look good so far. I'll update once I get my C7G and actually mount it, but thanks again for being so quick about shipping this out, and for the communication and good craftsmanship I really appreciate it.
I see that on overclockers website the estimated ETA for the C7 is 9/20. We might still have to wait a bit.
TheGrine
Yes I would like to know that too ! Im in Canada if anyone has a solution for the SCBSK-2100 Big Shuriken 2 Rev. B for AM4 please tell me !
I made a 3D-printed adapter for that.
All you need is a standard #2 pencil.
It's a bit odd, but so far it's working for me:
Poblopuablo
816
465
Does that work for the rev b?
