Yep, mine is Rev. B!Does that work for the rev b?
Will clarify that.
But it should also work with other similar coolers (with minor modifications).
I can share my Fusion 360 models if anyone is interested.
This bracket could be made also with a CNC mill. Wow!
I got the adapter. Seems that one of the screw points might not be completely perpendicular to the surface, which makes the bracket bow and flex.
It fits well with my motherboard. I am using a Gigabyte AB350N, which generally has low profile components, so I can't say how well this would fit with the later X570 motherboards.
I didn't try putting the 3D printed one, nor the original backplate as it ended up too difficult to try getting all 4 screws through, but the mounting screws at least easily fit through the AM4 motherboard holes. Also, I was wondering if your current 120mm Cryorig C7 adapter available in your store would work with the 90 degree mounted Cryorig C7 while maintaining compatibility with RAM? If so I may just purchase one to ship along with the replacement, so let me know.
In that case, I just might get the normal 92mm adapter. I pm'ed you the order number for the original 90 degree mount.Glad to hear that fits without hitting components.
120mm fan mounting would fit as long as your heatsink sits 2mm taller than your RAM. Though, it may not actually be better performance, since a lot of the airflow will miss the heatsink.
Received the product today. Pics and details:
EDIT: Forgot to mention, motherboard is ROG Strix B450-i.
Hello,
Did you try placing the washer between the stand off screw and the bracket? It extends the length of the screws so it adds some height on the opposite side of the motherboard.
