Production AM4 Brackets for CPU Coolers (C7 + others)
T_Tank
137
113
Would totally be interested in a proper big shuriken 2 rev b am4 mount. I'd take measurements but that mean I have to undo my noctua bracket Jerry rig and be without a heatsink
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
@Thehack If you order those, do you have a vague timing for it ?
DEC/JAN time frame is what I'm looking at. I'll have to double check the details and place an order in a few weeks.
Yes, that's a good idea as well. Did you have to drill out your noctua bracket to make it fit? A proper Big Shuriken 2 bracket would be good.
I'll be making a small order to see if there is some demand on it and then make ones for the Big Shuriken 2.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
With the release of the Black Ridge cooler at 48mm, do you guys see a purpose of this anymore? at 48mm, it comes with AM4 support out of the box. It is also only 61mm if you use a slim fan on top, making it very close to the Big Shuriken 2.
T_Tank
137
113
Yeah I had to drill out the bracket prices that bolt directly to the heatsink and use the noctua backplate not super ideal as the screws to the backplate rub just barely.
Really not ideal but I can't complain with the results in cooling even with air flow reversed so it doesn't fight the exhaust fabs
DwarfLord
56
31
Thanks for the answer ! I'll go ghetto-mod in the meantime, wish me luck :cool:
There is still some cases where 48mm is too much, as in my case with the M350 (44mm free space, and even 40mm max with fan on top of the cooler if you don't want to have the fan making awful noises from the proximity with the top of the case). But it would be totally understandable not to do it anymore for such a niche market ;)
Skinz
26
Dan said in his post that the Black Ridge was 2C cooler than the l9, and considering that to be under 48mm, it needs a fan underneath, then there could still be a demand for this, unless a lot of people swap to VLP ram.
Skinz
26
Alright. I'll get a small batch made and see how that goes. I'll place the order in the next batch of stuff.
Just so I am being accurate, below is the quote from Dan. Hopefully he doesn't mind me putting it over here. The performance with vlp looks very good, but I calculated for me to get decent vlp for ryzen, it is $US 240, not even counting shipping to Aus. I'd be curious to see how a C7 would perform with the better mount, plus a duct and a noctua a9x14. Maybe the LP53 too, if the cost is worth the performance.
*snip*
Btw here are some results of the Black Ridge made on an erlay sample I god month ago from EKL:
L9i @ 2400rpm = 63°C
Black Ridge (default 92mm fan) @ 2400rpm =61°C
Black Ridge + A12x15 (120mm fan under fin package) @1800rpm = 52°C
Black Ridge + A12x15 (120mm fan above fin package) @1800rpm = 50°C
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
I would say it may not be worth it for a C7 in a Dancase, since the issue is that it is too close to the side panel.
What case do you have?
Reactions: fabio
Skinz
26
Currently getting my build lined up (work takes too much time in my life). I am leaning towards the Dan Case, but potentially may get something like the Skyreach, but the PSU options are what is holding me up (Want to run a vega 56 and either a Ryzen 2600 or 2700).
Skinz
26
Do you think it is worth it for an l9a? I am tossing up between the l9a and the C7 for a 2600.
TheHig
951
1,171
I ran a 2600 just fine in the S4 mini with the L9a. I also tried the C7 in a Node 202 and found the fan to be unpleasantly loud.
Right now the L9a or i is tough to beat for low profile cooling.
Reactions: fabio
Skinz
26
Cheers for that. I think I will get the L9a, maybe with the TY-100 fan and duct, i just cannot find any data on if it gives an improvement.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
I've ordered a set of C7 brackets.
I need to test how it fits first. And see if there is enough interest in putting a large order.
Big shuriken 2 is in the works if the C7 version sells.
Skinz
26
Cheers for the update @Thehack I am inspired by your Skyreach build, and am actually doing a build soon with a 2600x and L9a. Did you notice much of an improvement with the Ty-100? Also, looking at your Skyreach build, do you think the L9a would fit on AM4 when mounted differently? Judging by the ty-100 it looks like it might not?
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Thanks!
I did not notice much of an improvement, it certainly is 100% less brown though ;)
The L9a would not fit if rotated 90 degress (for proper exhaust airflow). The cooler is actually about 115mm lengthwise. Fin length 110mm. I think the TY-100 helps with a bit more performance, but I can't say because I am not a tester.
