Power Supply 500W FlexATX PSU
HeroXLazer
707
476
THE USA's...
First version of drawing complete!
Today I've finally completed a first version of the drawing! Link to PDF.
If anyone finds a mistake or has objections, please tell me! The division of connectors to the 12V rails is not final, everything else seems pretty much fine to me.
I'll add this to the first post so people can find it easily.
Wait, what's this for? I didn't understand this thread?
EdZ
Virtual Realist
May 11, 2015
1,577
2,108
UK
Is P2 a 'jumper' to connect an outboard -12V generating solution? P11 is also absent from he pinout description.
My gut reaction would be to split P4 and P5 between the 12v1 and 12v2 rails, as almost any use case requiring two PEG connectors will have the GPU as the highest drawing load. Maybe:
P1 (ATX) on 12v1, P3 (EPS) on 12v2, P4 (PEG1) on 12v2 and P5 (PEG2) on 12v1. That way the 'low power' ATX + PEG use-case is evenly distributed between rails, and both the CPU and GPU can their draw between rails when fully populated.
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
Germany
freilite.com
That is correct.
Ah yes, P11 should be implemented as a header inside the PSU or left unpopulated as most people won't need it. I forgot to remove it, thanks for the heads-up!
Yes, I feel like this might be the best way to do it. I kind of fear that people might use a high-powered CPU and GPU and then overload 12V2, but with both rails being equally rated, there's not much to do better there.
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
Germany
freilite.com
Ok, I submitted a corrected version of the drawing and a final list of modifications for the PSU, which are:
  1. Modified cable harness
  2. Black case
  3. No "Full-RPM" of the fan on start-up
  4. No external cable retention (my unit didn't have that, but I included it for completeness)
  5. Mounting flange at the front
Unfortunately, requirement 3 might not be possible to implement and with bad luck requirement 2 could raise the MOQ to 500, but so far I don't know for sure either way. I'll post a proper update once I get more info, and then we can still decide what route to take if there are multiple choices emerging.
GeSong
I can't give an ETA yet because I have to wait for FSP to respond to my inquiry. Depending on their schedule it could still take a few months, even if we ordered today.
I'm not in a hurry to get a PSU. Whenever this custom version is open to order, please shoot me a message and I will be glad to order one.
Necere
3,300
FYI FSP tells us the FSP500-50FGGBN, a 500W, Gold-rated flexATX PSU will have -12v, with samples scheduled for June. They also have a least one other higher wattage flexATX in development.
Reactions: Phuncz and jeshikat
