Power Supply FSP FSP500-30AS Modular Flex PSU from GEEEK, anyone have one?
fncalderong
What I found in previous posts is this: as a distribution of the 10 pin connector:
Looking into the 10pin from the connector side with the clip on top:
_________Latch__________
3.3v Gnd PWOn Gnd Gnd
3.3v Gnd 5Vsb 12v 12v
________________________
So I assume I need to connect the 2nd and the 3 rd to make it work.
vinnyoflegend
146
95
Thanks for your help, so I must jumper the 2nd and the 3rd on the 10 pin connector right?
This map is correct for the one with 10p connector. Middle pin closest to the latch to any of the grounds.
This is how I test the PSU prior to any modifications. I leave it shorted with a bent paperclip and check all the voltages of the remaining pins with a multimeter.
fncalderong
Thanks my friend! Appreciate your help and guidance.
