I appreciate the detailed explanation, but what I meant was that your usernames are so similar that I often mix them up![]()
I use a Duplicator i3Sorry I'm late to the party, but...
Could I ask what 3d printers you guys are using (sorry if this has been answered earlier)?
I'm really digging the Creality CR-10 for its large build volume, and the MK2S for its raw reliability and quality. Anyways, man 3d printing just opens up so many doors. I was just messing around in Fusion 360 today and I think something like this would totally be doable, provided you had enough motivation for sanding + finishing.
BTW, the front is lowered like that to fit a 240mm radiator. The back then raises it up a bit to get airflow for the Mobo/GPU.
It's totally fine to ask about thatIs it okay to ask about printing services here? Looking to do a print but kinda need to temper with my expectations on accuracy. There's a 2.5mm screw hole on each corner and I worry the positions of those holes might inch closer if the model shrinks too much while cooling. kinda looking at shapeways at the moment
(the last time I mentioned checking out the printer in the library: they only do PLA and print runs cannot exceed 45 mins ._.)
Oh totally. I've used them once and it was accurate (although I did use the wrong scale factor. *Facepalm*)I can vouch for Shapeways quality. All prints I've received from them are top notch.
i wouldnt even bother tryin to print that. Laser cut it out of acrylic or plasma cut it out of aluminum.Yeah I'm back. didn't make enough progress, so here's the tidiest (but still incomplete) plan of what I'm shooting for so far
would this work? >_<
That's actually pretty cool! Could print practically an entire case's worth of components with that build area.build area apparently a bit under 1ft cubed
